SolaraGuy.com • View topic - Question about fog lights?
Postby LatinDragonXJC » Fri Nov 04, 2005 3:50 am
I never bothered to check until tonight, but my fog lights weren't on. Are they supposed to turn on as soon as the headlights come on? or Do I need to change them? Thanks in advance.
LatinDragonXJC
Postby StockSolara » Fri Nov 04, 2005 4:43 am
Yeah they turn on with the head lights. . . Make sure you have the switch for the fog lights on. . . also check out the bulb and look for the fuse. . . and if that doesn't work than I don't know maybe someone that knows more about fog lights can help you out
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby bassthrive » Fri Nov 04, 2005 6:48 am
my foglights only turn on if i have the foglight switch on the left control stalk switched on. regardless if you set your main headlights to off (auto) or on, the fogs will only come on if that secondary fog switch is turned/kept in the on position.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby SleeperSolara » Fri Nov 04, 2005 8:45 am
Straight from factory the fogs are suppose to come on only when you have the headlights on.
Some members on here have wired them to turn on command, regardless if the headlights are on or not.
Bulbs are burnt out or fuse out; check those.
Postby LatinDragonXJC » Fri Nov 04, 2005 9:28 am
Ok I thought about it a bit, now when you guys say headlights on, does that automatically include the DRLs at night or do I manually have to twist the stalk and turn on the headlights?
Ima replace them anyhow for some silverstars, one of my boys has a good discount at pep boys and Ima rack up tomorrow with goodies for her.
LatinDragonXJC
Postby Jon11582 » Fri Nov 04, 2005 11:50 am
For Gen1:
When no headlights, or DRLs are on, fogs stay off regardless of switch.
If you MANUALLY turn on headlights, foglights come on IF the switch for the fogs is on
If they come on because of the twilight sensor, foglights also come on IF the switch for the fogs is on.
If the switch for the fogs are off, they will come on under no circumstance
2000 Black Solara SE
Jon11582
Postby bronzemaxell » Fri Nov 04, 2005 1:20 pm
i've also found that the fog will SHUT OFF if the high beam is on, irregardless if the fog light switch is on or off.
bronzemaxell
Postby WTF?? » Fri Nov 04, 2005 4:19 pm
Jon11582 wrote:For Gen1:
bronzemaxell wrote:i've also found that the fog will SHUT OFF if the high beam is on, irregardless if the fog light switch is on or off.
These are the best descriptions to how/when fogs work and dont work
Retired... its been fun Image
WTF??
