SolaraGuy.com • View topic - Getting more out of our alternator?
Postby pythonjosh » Mon Nov 14, 2005 1:07 am
I was wondering what would be the best way to get more amps from our alternator. An idea came to mind that might work, and require no electrical knowledge. How would putting a slightly smaller pulley on the alternator work? It would spin a little bit faster than normal, cranking out more amps right? Would this work? And how and where would we be able to find a pulley that would work?
pythonjosh
Postby hskrsolara » Mon Nov 14, 2005 1:18 am
Hmm... That is an interesting idea. Any electrical experts here?
hskrsolara
Postby SleeperSolara » Mon Nov 14, 2005 8:17 am
It might work.
The new Celica's have an alternator belt for the undrive pulley set.
more power
Postby Sentinel » Mon Nov 14, 2005 10:10 am
I've never tried anything like that before, but I suspect that putting a smaller pulley on the Alt. will only allow it to make it's max power a bit earlier in the RPM range (I don;t think a normal alt will make max power at idle) but I don't think that it will allow the alternator make more power than it is rated at. That is going to be limited by the construction of the alternator.
There has got to be somewhere you can get a higher output alternator to bolt on, or maybe take it to a re-winding shop and see if they can wind it for more power.
Last note: not only does the killer system weigh more, but the more power your alternator puts out, the less HP to the Wheels!
(1hp = about 746 watts)
Sentinel
Postby pythonjosh » Mon Nov 14, 2005 4:12 pm
I've seen one every now and then on ebay, pushing out 120 amps. But I know this would be something I cna do myself, just don't know how. I'm kinda confused as to how putting a smaller pulley on the alternator would cost HP, physically.
pythonjosh
Postby BradOwens » Mon Nov 14, 2005 4:14 pm
yea that would be nice. when im sitting still and playing my subs my lights flicker
BradOwens
flickering horsepower
Postby Sentinel » Mon Nov 14, 2005 5:30 pm
If you flicker at idle with a good alternator because of your stereo, then a smaller pulley would help.
A smaller pulley wouldn't suck up any more HP, a bigger alternator pushing more power would. There is no such thing as a free lunch. :)
Sentinel
Postby Yanks0114 » Mon Nov 14, 2005 6:28 pm
Your best bet is to just look for a high output aftermarket alternator.
Postby ZXLNT » Mon Nov 14, 2005 10:46 pm
Denso makes a 200 amp alternator for the Solara..
ZXLNT
Postby pythonjosh » Mon Nov 14, 2005 11:00 pm
ZXLNT wrote:Denso makes a 200 amp alternator for the Solara..
I just looked at www.Denso.co.jp and also http://www.globaldensoproducts.com/ and couldn't find anything.
I did just find this one for $200+ship.....
http://cgi.ebay.com/ebaymotors/97-01-To ... enameZWDVW
pythonjosh
Postby WunLoudSolara » Tue Nov 15, 2005 12:17 pm
I got a 200amp alternator from excessive amperage for $430 shipped, works great, still some dimming but not much considering I have a total of 1900 watts RMS, putting a smaller pully on will just kick the alternator on at a lower engine RPM, but doing this on a stock alt. could possibley burn it up when driving at a higher RPM.
2000 Toyota Solara SE V6
Injen CAI
Gredy Evo
2 Power HX2 15
RF Power 1500bd & 450s
Sony CDX-M850MP
200Amp EA Alternator
Optima Blue Top Battery
MB Quart Premium 6 1/2 Components
WunLoudSolara
200 amp alternator
Postby hskrsolara » Tue Nov 15, 2005 1:16 pm
Where did you find it, how much did it cost???
hskrsolara
Postby JAYDEE23 » Tue Nov 15, 2005 6:40 pm
i am looking into this right now also..going to see what,if any options are available instaed of dishing out the 400+ for an upgrade
JAYDEE23
Postby StockSolara » Tue Nov 15, 2005 9:42 pm
http://www.mralternator.com/alternators/toyota.html
Yes the 94-02 Camry 3.0 Alternator will fit our car because Greg put it on his Solara
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby ZXLNT » Tue Nov 15, 2005 10:08 pm
well I should probably re-word. There is a 200 AMP Denso AVAILABLE for the Solara..
http://www.h-o-alternators.com/alternators.htm
ZXLNT
