SolaraGuy.com • View topic - overinflated tires
overinflated tires
overinflated tires
Postby newroc » Mon Nov 21, 2005 6:31 am
misread the gas stations' gage this morning and put 36psi in both front and 34 in the rear tires. car still handles pretty well though, and I kind of like it.
Is that safe? Do I need to bleed the tires to brind them down to 30-32psi?
newroc
Postby bassthrive » Mon Nov 21, 2005 7:09 am
36 sounds high. What size are your tires? Make sure you are using a quality gauge too. I made a post not too long ago about the inaccuracy of those cheap pen-style pressure gauges. The ones on the air hose at the gas station are usually even worse.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby newroc » Mon Nov 21, 2005 7:21 am
they're stock 205/65hr15 new tires. I know the all rubber bicycle tires w/ inner tubes are rated 60psi, so I suppose 36 for radial here aint gonna burst. I'll try it out for a few days.
unless any of you guys think it's not safe, then I'll bleed some of it out.
newroc
Postby SleeperSolara » Mon Nov 21, 2005 8:31 am
You should read the tire max psi rating.
Mine are 205/55/R16 and i put in 35-40 psi.
My tires max psi is 45.
So yeah you should read the max rating on your tires to see what psi you should put in there.
Postby Mole » Mon Nov 21, 2005 11:31 am
newroc wrote: I know the all rubber bicycle tires w/ inner tubes are rated 60psi, so I suppose 36 for radial here aint gonna burst. I'll try it out for a few days.
you are going to compare a mere bicycle tire with a car tire.... :roll:
there is a max psi for a reason. play it safe with 32psi.
Postby Ford_Fixorrepairdaily » Mon Nov 21, 2005 11:42 am
The psi rating is always on the tire. If you got stocks on, I think on your door sill there is a sticker that says how much is max inflation. But from what I can remember 45psi is max, I usually try to keep mine about 35- 40 range.
2002 Solara SLE V6 - Sold =*(
2006 S2000 - Weekend G Ride!
2009 - Fit Daily Grinder
Postby Jai_Jai_Binks » Mon Nov 21, 2005 11:51 am
some people claim that increased psi equated to increased mpg's. I would still keep it safe (geesh, i assumed it was 31 and thats what i keep it at..i need to read the sticker more often)
Postby Jon11582 » Mon Nov 21, 2005 2:31 pm
Read it again in the morning before you go out to work or something, Not sure how warm your tires were running when you got to the gas station, but it might be at an OK pressure at cold psi in the morning. Remember, max ratings and recommended ratings are all at Cold PSI.
2000 Black Solara SE
Jon11582
Postby Solorange » Mon Nov 21, 2005 2:41 pm
I always have mine at 37psi. The there is a max written on the door. You should be ok.
Postby TadS » Mon Nov 21, 2005 3:27 pm
There is a mfg. recommendation and a max tire pressure. They are not the same. I had a retard in the shop a couple of weeks ago that tried to belligerently defend his stupidity of grossly (like 50psi) over-inflating the tires on his corolla with “the tire says....” bullcrap. I was a dick to him and told him how retarded he was. I was like uhhhhh Toyota says 28 psi is right, but if you want to blow out your tires and wreck I guess that's your business. Hmmm… I guess if a retard like that wipes himself out, that’s good for the human race :).
Anyway, like was said above, that’s a bit high, but you should be “safe” I usually run a few psi high too for the sake of slightly better fuel economy.
TadS
Postby cRaCkeD oUt » Mon Nov 21, 2005 3:45 pm
36 is okay, but if you drive in the canyons or something for speed and fun, its gonna be a bouncy @$$ ride. The lower PSI you go is gonna be more grippy (not too low.. i.e.32). Average PSI should be like uh 34!
Own yaH! @_@
2005 Toyota Solara SE Sport 5Spd. I4- Artic White
cRaCkeD oUt
Postby Somedude » Mon Nov 21, 2005 3:51 pm
I usually keep my car's tires at 40 psi (all four tires).
Somedude
Postby NeFaRiOuS_SLE » Tue Nov 22, 2005 1:35 am
Stock tires:
205/60R15: 29 PSI
205/60R16: 32 PSI
Me = 36PSI for 124 MPH for the late-night need for speed on H-rated tires.
http://www.tirerack.com/tires/tiretech/ ... ?techid=72
Postby ThatVietGuy » Tue Nov 22, 2005 1:43 am
Cold, my tires are normally around 35 PSI
Warmed up (after about 15 minutes of driving), around 42 PSI
ThatVietGuy
Tire Pressure
Postby red2002solara » Tue Nov 22, 2005 4:07 pm
I always keep my tires at 35 psi or a tad above.
red2002solara
Users browsing this forum: Google [Bot] and 4 guests
