SolaraGuy.com • View topic - start up idle at 200....
Postby lilm » Thu Nov 24, 2005 3:20 pm
yep its happened 3 times in the last couple of weeks.....
i start up and it idles at 200 rpm....any ideas?
lilm
Postby BradOwens » Thu Nov 24, 2005 3:34 pm
200? do u mean 2000? i dont think ur car would be able to run at 200 rpms it would shut off
BradOwens
Postby JAYDEE23 » Fri Nov 25, 2005 9:29 am
yes completely normal..this has been cobered a few times since i have been here..will run 180-20 for a few minutes to warm up..
JAYDEE23
Postby WTF?? » Fri Nov 25, 2005 10:17 am
you guys GOTTA be talking about 2000rpm's... it does that for a few minutes to speed up the warm up process... dont rev it... just let it do that for a couple mins and itll drop back down to normal after the engine is warm.
at 180-200 i dont think any engine can stay idling :lol:
Retired... its been fun Image
WTF??
Postby lilm » Sun Nov 27, 2005 4:25 pm
nope guys i mean 200 rpm....its there for about 30 secs and then it dies
lilm
Postby DaTwUnKrAziEpInOy » Sun Nov 27, 2005 4:30 pm
hmmm.....maybe check your hoses, one of them could be torn or disconnected. I assume the check engine light turns on ??
DaTwUnKrAziEpInOy
Postby lilm » Sun Nov 27, 2005 4:56 pm
nope no problems of any kind just about 5-10 times a week it wont start then it starts to 200 rpm and shuts off then i try a couple more times and it evenutally starts
lilm
Postby Alex(AUS) » Sun Nov 27, 2005 10:11 pm
Clean the throttle body ... been covered before ... look in the tutorials.
Alex(AUS)
Alex(AUS)
Postby Jon11582 » Sun Nov 27, 2005 10:21 pm
Id check hoses and maybe spark plugs if your at 60K+ and never changed em. Happened to me a few times after I changed my intake due to a loose hose.
2000 Black Solara SE
Jon11582
Postby ClassySolaraGuy » Sun Nov 27, 2005 10:43 pm
sounds like a vac leak
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby SpeedSTARs » Sun Nov 27, 2005 11:23 pm
ClassySolaraGuy wrote:sounds like a vac leak
^^^Yep... Or maybe you need to replace the PCV valve. It could be clogged. Give that a shot. :wink:
SpeedSTARs
Postby ClassySolaraGuy » Mon Nov 28, 2005 1:31 am
Yeah, Check those hoses around the tb and around the manifold. You can always do the "WD-40" test. You spray the suspected hose that you might think the leak is coming while the engine is turned on.
If you notice a change in the engine (RPM Fluctuation) or if you notice to see the leak by the little bubbles created, then you found your problem. Even the tedious of vac leaks can cause your problem. Check very carefully! Hope that helps! 8)
SpeedSTARs wrote:Or maybe you need to replace the PCV valve. It could be clogged. Give that a shot.
Very possible too!
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
