SolaraGuy.com • View topic - 24/7 headlights
24/7 headlights
24/7 headlights
Postby black99 » Wed Nov 30, 2005 12:40 pm
How can I turn off my headlights? They are always on. Sometimes I would like to run my corners and fogs together without the headlights on. I now know how to do the independent fogs, but need this to make it all work the way I want it to work.
black99
Postby cklinh » Wed Nov 30, 2005 12:47 pm
Just a vague memory... just disconnect the DRL sensor? I think that was posted somewhere around here...
cklinh
Postby 1st Gen Sol » Wed Nov 30, 2005 1:09 pm
Under the hood on the passenger side, there is a gray plug. That is the DRL connection.......if you disconnect that your headlights will only come on automatically at night and not during the day.
Theres also other ways of disconnecting it the way you want.....just use the "Search" function.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby WTF?? » Wed Nov 30, 2005 1:26 pm
1st Gen Sol wrote:Under the hood on the passenger side, there is a gray plug.
yup, the DRL plug is more towards the windshield on passenger side.
The night sensor can also be disabled, but im unsure of the process :-?
Retired... its been fun Image
WTF??
Postby lilm » Wed Nov 30, 2005 10:51 pm
this has been beat to death
SEARCH
if your two lazy to search disconect the gray plug in the engine bay and for you to have TOTAL control get the little black sesor on the passanger side by the windshield pry it up and disconect the little sensor and youll HAVE to turn on the lights manually from now on :)
lilm
Postby SleeperSolara » Thu Dec 01, 2005 8:19 am
To add to that, you can also disconnect the fuse near the battery.
There will be a fuse box that will be in front of the battery.
Open it up and look the underside of the the cover and it will say which one is the DRL.
I think it is a red one.....
Postby xlxdarkmarinexlx » Thu Dec 01, 2005 8:24 am
actually the search function doesnt work sometimes or doesnt work properly...
Saepe Exertus, Semper Fidelis, Frater Infinitas Often Tested, Always Faithful, Brothers Forever
CPL*HUEY MWSS 473(-), MAG 47, 4th MAW
www.myspace.com/nwhuey
xlxdarkmarinexlx
Postby dominoSLEV6 » Thu Dec 01, 2005 10:17 am
Yes searching on this site can be difficult. I just tried a search knowing key words in threads about it and got nothin.
To disable the DRLs and nighttime auto sensors, IMO the easiest way is cutting the ground wire in the harness for it just behind the ingnition.
It takes a little working with to do it, but it's a sense of accomplishment and works just fine once you do it.
This page should tell you everything you need to know if you want to go that route.
http://www.legacytuning.com/DRL/DRLdisable.htm
-chris
dominoSLEV6
Postby black99 » Fri Dec 02, 2005 8:01 am
How had this post been beat to death, Im new here and Im sorry if I havent seen these threads before, why dont you quit being a douchebag and just help out like all of the other nice people.
To all of you who helped in a nice manner, thank you
black99
Postby SleeperSolara » Fri Dec 02, 2005 8:20 am
dominoSLEV6 wrote:Yes searching on this site can be difficult. I just tried a search knowing key words in threads about it and got nothin.
-chris
Tried don't work.
It will throw the brake light on like no other.
black99 wrote:How had this post been beat to death, Im new here and Im sorry if I havent seen these threads before, why dont you quit being a douchebag and just help out like all of the other nice people.
WTF????
Postby Ford_Fixorrepairdaily » Fri Dec 02, 2005 10:49 am
How come no one makes a sticky for this? Or any other important mods?
2002 Solara SLE V6 - Sold =*(
2006 S2000 - Weekend G Ride!
2009 - Fit Daily Grinder
Postby WTF?? » Fri Dec 02, 2005 11:11 am
Ford_Fixorrepairdaily wrote:How come no one makes a sticky for this? Or any other important mods?
cuz theres been discussion of different ways to do it and ppl argue over whats the "proper" way :roll:
geez... as long as it works! :bday:
WTF??
Postby 1st Gen Sol » Fri Dec 02, 2005 1:35 pm
The only proper way would be to buy a Solara with the option of the DRL switched to auto or left off. :roll:
Otherwise it'll be the ways we've all done it by unplugging the gray plug in the enginebay & on the dashboard, popping the fuse out the fuse box or actually splicing wires to disable the DRL. 8)
How did you decide to disable the DRL if you haven't already by the way ? ?
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby black99 » Fri Dec 02, 2005 8:48 pm
I dunno, just tired of daytime running lights
black99
