SolaraGuy.com • View topic - Clock, Replacement 2001
Postby Omes01SLE » Sun Dec 04, 2005 8:07 am
I have a 2001 SLE and My Clock stopped working the other day, and I've checked both fuse locations (dash and engine) and the fuses are fine.
How do I go about removing the clock? Do I need to remove the entire center console (radio/heater) area or can I just remove the clock.
any help would be most appreciated.
thanks.
Omes01SLE
Re: Clock, Replacement 2001
Postby BradOwens » Sun Dec 04, 2005 8:11 am
Omes01SLE wrote:I have a 2001 SLE and My Clock stopped working the other day, and I've checked both fuse locations (dash and engine) and the fuses are fine.
thanks.
yes u need to remove the whole center console piece but not the radio and hvac they stay in place. its not hard. when u get it out the clock is near the top and its got like 2 screws holding it in and bam ur done.
BradOwens
Postby Omes01SLE » Sun Dec 04, 2005 8:30 am
great, thanks - that's a releif. How do I go about take out the trim around the center console? I took a look and don't see any screws or clips (the car has an aftermarket wood trim on the center console, so I don't know if that's hiding any of the screws/clips or not)
Omes01SLE
Postby BradOwens » Sun Dec 04, 2005 8:34 am
Omes01SLE wrote:great, thanks - that's a releif. How do I go about take out the trim around the center console? I took a look and don't see any screws or clips (the car has an aftermarket wood trim on the center console, so I don't know if that's hiding any of the screws/clips or not)
no screws. just stick a screwdriver(flat head works best) in tht crack near the cd player. play around with it and the whole piece should come out.
BradOwens
Postby Nyyankees3511 » Sun Dec 04, 2005 8:38 am
Or you can take the ash tray out and pull on the bottom and it will come out.
Nyyankees3511
Postby JAYDEE23 » Sun Dec 04, 2005 9:09 am
Nyyankees3511 wrote:Or you can take the ash tray and lighter out and pull on the bottom and it will come out.
this is the correct method..you need to remove the ashtray and lighter. put your fingers inside the bottom corners of the black trim and give it a good tug..it will pop out of the clips. the remainder of the trim is also held in by clips. just move up and continue to pull.
do not use a screw driver in any part of removal as it will leave marks in your plastic if you are not ectremely careful and it is unecessary
no offense to any who volunteered help..
after the trim is removed you will need to push in the little buttons on the clips of the clock and heating controls and pull the wire harness out. as for the clock i dont know but i cant be much work from this point
to reinstall just do above in reverse
JAYDEE23
Postby BradOwens » Sun Dec 04, 2005 9:23 am
JAYDEE23 wrote:
Nyyankees3511 wrote:Or you can take the ash tray out and pull on the bottom and it will come out.
this is the correct method..you need to remove the ashtray. put your fingers inside the bottom corners of the black trim and give it a good tug..it will pop out of the clips. the remainder of the trim is also held in by clips. just move up and continue to pull.
never knew about that way. yea do it this way Omes01SLE. when i had to take it with the screwdriver i had to be careful but i never bent the plastic.
BradOwens
