SolaraGuy.com • View topic - ChangingWaterpump
ChangingWaterpump
ChangingWaterpump
Postby RichD978 » Wed Dec 21, 2005 9:45 am
Is this a DIY job? Or would I have to get it done at a dealership/shop ? When I had my timing belt changed, the dealer didn't change the pump cause they said "it was still good"
RichD978
Postby indiglosolara » Wed Dec 21, 2005 10:03 am
Have the dealer do it...
its allot of labor..
if you are very mechinally inclined you can try it yourself but if you screw up its a pain to fix..
Plus if you do timing belt they will do the water pump for a very little extra since they will have everything apart for timing anyways..
indiglosolara
Solara 2 xB
Solara 2 xB
Re: ChangingWaterpump
Postby Turbosolara » Wed Dec 21, 2005 10:48 am
RichD978 wrote:Is this a DIY job? Or would I have to get it done at a dealership/shop ? When I had my timing belt changed, the dealer didn't change the pump cause they said "it was still good"
it is a bullshit because it is recommend to replace it at same time, save you labor time/money. (same procedure, that they have to take out timing belt).
so when you replace the water pump, you will have to pay more for the labor.
Postby bassthrive » Wed Dec 21, 2005 10:57 am
90k miles for belts/pump correct?
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby 1st Gen Sol » Wed Dec 21, 2005 11:10 am
I had my Avee serviced with 100k miles on it.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby SleeperSolara » Wed Dec 21, 2005 12:11 pm
That messed up.
The dealership shoul've changed your water pump while they were doin' the timin' belt.
Just got mine done Mon and should be ready for today.....
Postby Solorange » Thu Dec 22, 2005 2:58 pm
When I called all the local toyota dealerships for quotes on the timing belt and water pump replacement, one dealership told me that they dont replace the water pump unless if its bad. They told me it doesnt make sense. I asked what if i want you to replace it regardless and they just said they would have to check it out first. Then the other one said they agree that I should do them at the same time. They were also like 75 bucks cheaper so i guess Ill be taking it to them.
Postby WTF?? » Thu Dec 22, 2005 10:18 pm
SleeperSolara wrote:Just got mine done Mon and should be ready for today.....
damm that shop is slow...
when i did minea yr ago, i dropped it off in the morning and picked up it up around 3pm... i know they take theiur swt azzz time too :D
Retired... its been fun Image
WTF??
Postby DaveMush » Wed Dec 28, 2005 8:37 pm
Which engine are we talking about?
177Hp/186Tq Stock and OBDII compliant...
Dyno
DaveMush
Users browsing this forum: Google [Bot] and 33 guests
