SolaraGuy.com • View topic - Damaged Caliper Piston
Postby ~Spadwaller~ » Fri Dec 23, 2005 11:01 am
I was replacing my front brake pads and I noticed that the rubber seal around the piston in the caliper had a huge hole. Is this serious, should I get this repaired immediately?
~Spadwaller~
Postby Grazi07 » Fri Dec 23, 2005 11:23 am
Safest option would be to replace it, but if you're not losing fluid and not feeling a difference in braking performance, then you can probably wait a bit.
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby ~Spadwaller~ » Fri Dec 23, 2005 11:30 am
Replace the whole caliper, aww man :(
~Spadwaller~
Postby Grazi07 » Fri Dec 23, 2005 1:28 pm
you might only have to do the piston itself, I'm not sure if a new one will come with the seal I think you're talking about or not.
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby Assyrian » Fri Dec 23, 2005 2:29 pm
I don't know... maybe it's just me... but I would just replace the whole darn thing out of fear haha.
-Edgar
A noobie with an 02 SEV6 MTX
Assyrian
Postby Grazi07 » Fri Dec 23, 2005 2:41 pm
As far as I know, the piston is the only "mechanical" portion of the caliper. As long as the calpier housing isn't cracked and you can re-seat the new piston cleanly, I don't think there's a reason to do the whole thing.
If you've got any mod money, maybe you could experiment with fitting a multi-piston caliper?
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby ~Spadwaller~ » Fri Dec 23, 2005 2:47 pm
Clarificaton: its the piston boot that is shredded.
Kinda like this pic
~Spadwaller~
Postby SleeperSolara » Fri Dec 23, 2005 2:53 pm
Grazi07 wrote:As far as I know, the piston is the only "mechanical" portion of the caliper. As long as the calpier housing isn't cracked and you can re-seat the new piston cleanly, I don't think there's a reason to do the whole thing.
Yeah would be cool.
No man all you have to so is buy a caliper seal package.
It happened to me too.
I saw a tear in my caliper seal too, and ordered a caliper seal package from the dealership; and replaced to torn rubber seal it a new one and the metal rings that hold it in place.
I suggest you use a shallow tray to hold the fluid that comes out when you take the caliper off.
Will be slippery when you take it apart.
Will be a 1 hour job i think.......
Good luck man.
PM or IM me on AOL if you need help.
I've done it, but my brakes still feel spongy... :-? [ I think it the master cylinder]
Postby SleeperSolara » Fri Dec 23, 2005 2:56 pm
~Spadwaller~ wrote:Clarificaton: its the piston boot that is shredded.
Kinda like this pic
I thought we had 1 piston.
That looks like part of the caliper is broken, and the rubber is partly torn.
Postby ThatVietGuy » Fri Dec 23, 2005 3:01 pm
He's just using that as an example...
If it were me, I'd just replace the damn thing :P
ThatVietGuy
Users browsing this forum: Google [Bot] and 33 guests
