SolaraGuy.com • View topic - **UPDATE** on: Seafoam on Solara?????
Postby SleeperSolara » Thu Dec 29, 2005 10:48 am
Well i helped my friend wit his Steath TT wit the SeaFoam, on cleanin' his intake manifold.
There was a tube to took off and you let the car kind-of suck it in to clean the intake manifold; then after a while the would be smoke comin' from the exhaust and the where eva there was an exhaust leak.
So my question is there a tube where i can have the intake manifold suck up the SeaFoam to clean the intake manifold?????
Cause i think i'm goin' to do that to clean the intake manifold and the throttle body.
Thanks for the input.
Postby Assyrian » Thu Dec 29, 2005 10:56 am
great question... anyone have an answer?
-Edgar
A noobie with an 02 SEV6 MTX
Assyrian
Postby Strider327 » Thu Dec 29, 2005 1:06 pm
Brake Booster Line. Located on driver side toward the frame of the car. Black tube connected to a big black circular shape thing.
Strider327
Postby Grazi07 » Thu Dec 29, 2005 1:14 pm
^ Sounds like the fuel line/filter, be careful. Pics are probably a good idea.
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby SleeperSolara » Thu Dec 29, 2005 4:23 pm
Strider327 wrote:Brake Booster Line. Located on driver side toward the frame of the car. Black tube connected to a big black circular shape thing.
Well i just looked at my car.........
I see the tube it has a white thingy near the brake reserivor cap, it that it????
It does lead to the intake manifold.
Hope it the right one.
Have you done it????
Thanks for the info.
Postby StockSolara » Thu Dec 29, 2005 5:48 pm
Yeah thats the one. . . You should buy two cans put one can in the fuel tank, half a can to be sucked up and half a can poured into the engine oil. . . You should pour it in the last 50 miles before you have to change your oil
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Strider327 » Thu Dec 29, 2005 7:14 pm
http://www.cardomain.com/ride/515145/1
Look at the pic on 8/9/05. That black line is the one.
Strider327
Postby SleeperSolara » Thu Dec 29, 2005 7:56 pm
StockSolara wrote:Yeah thats the one. . . You should buy two cans put one can in the fuel tank, half a can to be sucked up and half a can poured into the engine oil. . . You should pour it in the last 50 miles before you have to change your oil
Really?????
That alot.
Postby SleeperSolara » Fri Dec 30, 2005 5:53 pm
Well i got done wit my Seafoamin' of my car.
:o :o :o :o :o :o :o :o :o :o :o :o
Man i got alot of white smoke.
For the 5 minutes i drove got alot of white smoke.
Scared a woman on 39th cause of the white smoke comin' from my exhaust. :lol: :lol:
But i drove around for 5 minutes and then checked the exhuast cause when i got it from "Grazi07" there was carbon build up in the tip.
Well when i looked at it when i finished drivin' it was almost gone.
I was suprised. :D
Postby bassthrive » Fri Dec 30, 2005 6:09 pm
1/3 in gas tank, 1/3 sucked through brake booster, 1/3 in crankcase
do it in that order, letting the engine run to circulate the seafoam in the oil. change your oil and filter right away. you dont want the gunk that seafoam loosens to be floating around your engine for any extended length of time.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby SleeperSolara » Fri Dec 30, 2005 8:50 pm
bassthrive wrote:1/3 in gas tank, 1/3 sucked through brake booster, 1/3 in crankcase
Well i put 8oz in the intake manifold.
Will be puttin' the other 8oz in the oil crankcase.
When should i put in the Seafoam in the crankcase???
I'm at 1200k miles on the oil, i have 800 miles left.
I just filled up too so Seafoam would be useless i use it 1/4 empty.
Postby Mole » Sat Dec 31, 2005 2:30 am
just what is seafoam ???? ????
Postby StockSolara » Sat Dec 31, 2005 2:37 am
Mole wrote:just what is seafoam ???? ????
http://seafoamsales.com/motorTuneUpTechGas.htm
2000 Lexus GS400
StockSolara
Postby Nyyankees3511 » Sat Dec 31, 2005 4:30 pm
Dont you have to change the spark plugs after you do this?
Nyyankees3511
Postby Mole » Sat Dec 31, 2005 6:04 pm
hahaha.... im going to do circles in a parking lot after seeing this
http://videos.streetfire.net/Player.asp ... 33F40F&p=1
