SolaraGuy.com • View topic - Upper Strut Mount Question
Postby so1234 » Thu Jan 05, 2006 9:41 am
Hi,
I have got a 99 SE V6 with the noise from the front end.
I have read that the Upper Strut Mount problem of the 99 Solara will return after we replace them. Should I fix it or just stay with it? Is there any way so that we can fix that noise completelly?
Thank you for your input
so1234
Postby drock03 » Thu Jan 05, 2006 10:59 am
Suspension - Front Support Change Reduces Noise
Bulletin Number:
SU001-00
Group:
SUSPENSION
Date:
January21, 2000
Title:
FRONT SUSPENSION SUPPORT NOISE
Models:
'97 - '99 Avalon & '97 - '00 Camry
TSB Update Notice:
The information contained in this TSB updates SUOO2-99 dated September 3, 1999.
Introduction:
To eliminate a noise occurrence from the front suspension on washboard type road surfaces, the suspension support has been changed.
Applicable Vehicles:
1997 - 1999 Model Year Avalon and 1997 - 2000 Camry vehicles.
Production Change Information:
The rubber bushing shape of the suspension support has been changed.
Parts Information
Warranty Information
Applicable Warranty*:
This repair is covered under the Toyota Basic Warranty. This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle's in-service date.
* Warranty application is limited to correction of a problem based upon a customer's specific complaint.
The part diagrams and numbers didn't copy...If you want more info PM me
drock03
Postby Assyrian » Thu Jan 05, 2006 11:02 am
wow! great info! that should help on future searches.
-Edgar
A noobie with an 02 SEV6 MTX
Assyrian
Postby Jai_Jai_Binks » Thu Jan 05, 2006 11:39 am
I've had that problem on my camry, not on my solara! If you ahve a problem, go ahead and replace the strut mounts, and from what i've been here since many many moons ago, this problem doesn't plague solaras.
Postby so1234 » Thu Jan 05, 2006 4:33 pm
Thank you for your responses.
I have read some post here, which say the problem would come back just a couple months after we replace the strut mounts. ( http://www.solaraguy.org/viewtopic.php? ... e&start=15 )
Is the any of you have the problem fixed completelly?
Thanks,
so1234
Postby drock03 » Thu Jan 05, 2006 6:06 pm
Not sure, but the TSB states the part was redesigned. Not sure if a re-occuring problem was because this new part was not use to fix?
drock03
