SolaraGuy.com • View topic - ABS Light
ABS Light
ABS Light
Postby BigPhizzle » Sat Jan 28, 2006 3:13 am
My ABS light just came on in my gauge cluster... Anyone know what the problem(s) may be? There are no notable symptoms that have followed the light turning on. Thx in advance for ur advice!
- Big Phizzle -
BigPhizzle
Postby SleeperSolara » Sat Jan 28, 2006 10:28 am
You would have to check the ABS code.
If you have the Haynes manual you will have to find out what plugs you have to plug the wire in 2 sockets and the ABS will flash a code in a number of blinks.
If you need to find out what sockets to stick it in then let me know.
Postby BigPhizzle » Tue Jan 31, 2006 11:56 pm
SleeperSolara wrote:You would have to check the ABS code.
Woah,.. thanks for the info sleeper, but thats a lil abstract for my unknowledgable self.. First off I have no haynes manual, and I dont know where to get one :-? .. second, what is the "plug the wire in 2 sockets" about? and where will the flash code blink? I appreciate the reply, but it was a little abstract. If you can clarify it a little, it'd be greatly appreciated. Thanks!
- Big Phizzle -
BigPhizzle
Postby DrakkkarDarkbladE » Wed Feb 01, 2006 5:41 am
This could be one of the speed sensors. In this case nothing would seem like it is wrong. Because the car still has atleast one other speed sensor. And the speed sensor does not impact on anything mechanically. You would have to scan the computer to find out which one it is.
This is just my 2 cents and I also had the same problem with one of my cars.
Get second opinion from a more experienced Solara person.
2002 SLE V6
"Great minds discuss ideas; Average minds discuss events; Small minds discuss people." - Eleanor Roosevelt
DrakkkarDarkbladE
Postby SleeperSolara » Wed Feb 01, 2006 8:08 am
BigPhizzle wrote:Woah,.. thanks for the info sleeper, but thats a lil abstract for my unknowledgable self.. First off I have no haynes manual, and I dont know where to get one :-? .. second, what is the "plug the wire in 2 sockets" about? and where will the flash code blink? I appreciate the reply, but it was a little abstract. If you can clarify it a little, it'd be greatly appreciated. Thanks!
Oh, my bad you can get a Haynes manual at AutoZone, or PepBoys, or even O-Reilly.
But i can take a picture of the picture from the book so you can find the code or i can take a picture of the location in the engine bay for you and put the wires in to show you where to find the sockets.
And then show you how to look for the code.
Postby silentblu » Sat Apr 29, 2006 12:57 am
can you take a picture of that for me? the wiring for the engine bay? thanks, i'm not quite sure but i believe it is a speed sensor, and the abs light is limiting the car, anything after 80 it struggles now, i usually odn't have a problem getting to like 100, since it has an SC
silentblu
