SolaraGuy.com • View topic - Auto Trans and Hand Brakes
Postby minchman » Mon Mar 20, 2006 12:55 pm
I have a quick question for those mechanically knowledgeable members. I accidentally spilled about half a cup of coffee into the center console this morning. Luckily, most of the coffee fell into and around the cup holders. However, some small amount of coffee did seep through e-brake boot, and the transmission. The drive to work this morning was fine. Nothing really out of the ordinary.
My question is, are the parts under the console sealed? Can liquid cause damage? Thanks in advance.
minchman
Postby Paladin06Greg » Mon Mar 20, 2006 1:08 pm
LOL, you should be OK..
Paladin06Greg
Torqued Solara
Torqued Solara
Postby RichD978 » Mon Mar 20, 2006 1:11 pm
IIRC, i think there is nothing down there just a few wires connected to the e brake. If you want to clean it to get rid of the coffee smell and the annoying fact that you spilled coffee down there just take the center console out.
Theres 2 screws in the front (just pop the thing that goes around the shifter off to get to it) and inside the armrest thing that opens there are 2 bolts. Once you get those off it comes right out. You can even use the hose and get some pressure wash on those cupholders.
RichD978
Postby sahuddleston » Mon Mar 20, 2006 1:14 pm
you are fine man, no worries.
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby Hsakuragi » Mon Mar 20, 2006 3:25 pm
ants will all over the in your car....
j/k..it'll be fine~
Hsakuragi
It depends..
Postby JMSinMaryland » Mon Mar 20, 2006 3:43 pm
If it was decaf you won't have any problems, if it was regular you might find your transmission shifting faster. In the case that you drive a 4 cylinder you might want to spill some on the engine as well :wink: . Jon.
JMSinMaryland
Re: It depends..
Postby NeFaRiOuS_SLE » Tue Mar 28, 2006 1:49 am
JMSinMaryland wrote:If it was decaf you won't have any problems, if it was regular you might find your transmission shifting faster. In the case that you drive a 4 cylinder you might want to spill some on the engine as well :wink: . Jon.
Really? I got a 0-60 of 4.6 seconds and a lower 10's quarter mile on mine (and probably even actually sent some power to the rear wheels because the handling was C R I S P), but I guess my car reacts differently (but then again it was an extra-strong Columbian brew, e.g. more beans). Anyway, that should be about it electronics-wise in a 4-banger, but an SLE with factory security has its "brains" underneath the cupholder that's about 3" X 3" X 3/4" too, so you got less to worry about.
Postby bassthrive » Tue Mar 28, 2006 12:04 pm
You should be ok, as long as your flux capacitor and time circuits didn't get wet.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby krook » Tue Mar 28, 2006 3:53 pm
yeah, but if THAT were the case, he'd already have gone back in time and NOT bought that cup o' joe at the Faststop 2 blocks down from his house. c'mon McFly. :p
krook
Postby Duffman » Tue Mar 28, 2006 5:39 pm
Try some expresso in the gas tank. You'll do 0-60 in negative seconds. :x
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Users browsing this forum: Google [Bot] and 13 guests
