SolaraGuy.com • View topic - Traction Control
Traction Control
Traction Control
Postby Brad » Tue Jan 28, 2003 7:05 am
Hi guys - I've got a '99 SLE V6 and the Traction control has been giving me problems for some time now. It has been cutting in and out periodically over the past couple of years and now it seems to be out for good. The light shows Trac Control Off and pressing the button does no good. Is this a common problem? Can anyone give me a starting point on what might be wrong? Thanks a lot.
Brad
Brad
Re: Traction Control
Postby Flipside909 » Tue Jan 28, 2003 1:15 pm
Brad wrote:Hi guys - I've got a '99 SLE V6 and the Traction control has been giving me problems for some time now. It has been cutting in and out periodically over the past couple of years and now it seems to be out for good. The light shows Trac Control Off and pressing the button does no good. Is this a common problem? Can anyone give me a starting point on what might be wrong? Thanks a lot.
Brad
You might wanna check to see if you have a burnt out fuse. I believe theres a fuse for that on the engine bay fuse box. Refer to your manual for details.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby ICUFG » Tue Jan 28, 2003 1:52 pm
Brad
If its cutting in and out it would not be the fuse.
ICUFG
Postby Yanks0114 » Tue Jan 28, 2003 1:55 pm
Brad
Your switch could be bad. I think you are going to have to take it to the dealer
Postby Mudd » Sun Jan 25, 2004 4:36 pm
To revive an old thread (see, the SEARCH function DOES work). I had something similar happned to me today. Raining out, gave it a little more throttle than usual around a corner, and the traction control went wiggy on me for a second (felt like it kicked in, then out), then the TRAC OFF light came on, and stays on. On top of that, I just had a check engine light come on today too.
I just bought the car (it was delivered on Thursday), a 2000 SLE, so I'm going to try resetting the ECU first, then see what happens. It ran fine, so I'm thinking something stupid like EGR or o2 sensor or something.
Just curious as to what would cause this.
Mudd
Postby dan99solara » Sun Jan 25, 2004 6:53 pm
do SE's not have traction control?
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby Mudd » Sun Jan 25, 2004 8:40 pm
No. It was only an option on SLEs.
dan99solara wrote:do SE's not have traction control?
Mudd
Re: what??
Postby kubi » Sun Jan 25, 2004 10:10 pm
aznqtboy984 wrote:i have a 99 SLE- I don't see a traction control button!!! Where is it located?
It's not a standard option, you might not have it.
Please stop humping my car, owner privilege!
kubi
Postby HKSV6SLE » Mon Jan 26, 2004 2:45 am
if you have it, it'll be in front of the shifter, in front of the cup holders.
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby Mudd » Mon Jan 26, 2004 9:15 pm
GOING BACK to the question at hand, anyone know what would cause the traction control light to come on and stay on (indicating that the traction control is off)? When I push the button, nothing happens - it stays off. I reset the ECU, and that turned the light off, but I'm wondering why that happened.
Mudd
