SolaraGuy.com • View topic - Question?
Question?
Question?
Postby Jai_Jai_Binks » Tue Jan 28, 2003 12:30 pm
When I bought my 2001 solara, I did not opt for the factory alarm system (RS300, i think that was what the dealership was selling to me). I did get the factory remotes with lock+unlock+panic functions (doh! ie. keyless entry). Anyhow, from a transaction on ebay, the seller gave me a free remote that has four buttons (lock+unlock+panic+trunk release). I will take this to the dealership to get it programmed...however, IS IT programable since all I have is keyless entry?? Any thoughts.....
Re: Question?
Postby Flipside909 » Tue Jan 28, 2003 1:11 pm
jhbhatia wrote:When I bought my 2001 solara, I did not opt for the factory alarm system (RS300, i think that was what the dealership was selling to me). I did get the factory remotes with lock+unlock+panic functions (doh! ie. keyless entry). Anyhow, from a transaction on ebay, the seller gave me a free remote that has four buttons (lock+unlock+panic+trunk release). I will take this to the dealership to get it programmed...however, IS IT programable since all I have is keyless entry?? Any thoughts.....
It depends. If you have the same remote transmitter as the factory keyless, that shouldn't be a problem. I don't remember if the different keyfobs work different frequencies. Sounds like they gave you a keyless entry from a newer Toyota or Avalon.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby NASTY » Tue Jan 28, 2003 1:51 pm
i think they'll have to add something to your car if you want the trunk release to work, since that wasnt available on '01's
'01 SLE V6
NASTY
Postby Jackass-Jeff » Tue Jan 28, 2003 3:06 pm
trunk release remotes started on 02s =]
1GR-FE ftw!
Jackass-Jeff
Postby krook » Tue Jan 28, 2003 8:54 pm
you need a trunk release selenoid. good luck on that if you're gettin' it installed at the dealership. may cost anywhere from $100-$250 MAYBE. . .
krook
Postby Jai_Jai_Binks » Wed Jan 29, 2003 2:04 pm
Thanks....If its going to cost me even close to that much, might as well recycle it back to ebay! Still i'm going to call them to see how much do they charge...thanks everyone!
