SolaraGuy.com • View topic - power door locks
power door locks
power door locks
Postby Grnarowana » Sun Apr 02, 2006 12:44 am
I have a 99' Solara and my powerdoor locks do not unlock when i disarm it! But they LOCK when i arm it!
CONFUSING! AND A HEADACHE. HELP!
How do I fix it?
Thanks.
Grnarowana
Postby SleeperSolara » Sun Apr 02, 2006 1:08 pm
It maybe the fuse?????
Re: power door locks
Postby krook » Mon Apr 03, 2006 5:40 pm
Grnarowana wrote:I have a 99' Solara and my powerdoor locks do not unlock when i disarm it! But they LOCK when i arm it!
How do I fix it?
Thanks.
is it an aftermarket alarm? does the door unlock when you use the power lock switch on the door, and NOT from the remote?
if it's an aftermarket alarm, the unlock tap may need to be re-done. if you want to check it yourself, it's probably tapped in the driver's kick panel with a 3M scotchlock connector. if you've no idea what i'm talkin' about then just take it back to where you got the alarm installed.
krook
Postby Grnarowana » Wed Apr 05, 2006 5:25 pm
I believe it came with the car.
It's only from the remote.
Grnarowana
Postby krook » Wed Apr 05, 2006 5:34 pm
Grnarowana wrote:I believe it came with the car.
it may have come with the car but what alarm is it!?! someone could have installed an aftermarket alarm in it and sold it to you implying that it's naturally part of the car.
one way to tell if it's a factory remote is to look on the back of the remote and if it has a Toyota logo on it, then it's a dead giveaway. go back to the factory.
did you try to unlock the car from the drivers door switch?
krook
Postby user99 » Wed Apr 12, 2006 1:52 pm
Here is a tricky one, when I get in my 99 SLE V6 Solara, and put the key in.. turn the ignition on, both doors UNLOCK. I thought this was aqward, anyone else car do this ?
99 Solara SLE V6, Automatic
user99
Postby Sap Z » Wed Apr 12, 2006 2:09 pm
^^yea..wierd
they are supposed to LOCK unless one of your doors is open.
SapZ
V6 SE DWP
Sap Z
Postby RichD978 » Wed Apr 12, 2006 2:09 pm
should be a wire check under the steering wheel column for any broken wires. I can tell you which color wire to look for when I work on Friday night
RichD978
Postby krook » Wed Apr 12, 2006 2:10 pm
user99 wrote:Here is a tricky one, when I get in my 99 SLE V6 Solara, and put the key in.. turn the ignition on, both doors UNLOCK. I thought this was awkward, anyone else car do this ?
the lock and unlock connections from your alarm might need to be reversed. do you have a remote? does the remote do the same thing?
if your car is doing this and you DON'T have a remote, you probably have an aftermarket alarm installed that hasn't been disconnected.
if you DO have a remote, and it's doing the same thing (UNLOCKING when you press the LOCK/ARM button on the remote) then the connections may need to be reversed.
krook
Postby user99 » Wed Apr 12, 2006 3:15 pm
No, the remote works just fine.. as the key does when you put it in the door and turn right twice (unlocks all doors). The only time it does this is when I turn the key or start the car.
user99
Postby krook » Wed Apr 12, 2006 7:21 pm
your unit needs to be replaced. what brand of keyless entry/alarm system do you have?
with the door shut properly and the ignition ON, the doors should lock. chances are that the circuit board of the unit is f*cked.
i've seen weird things like this happen on "no-name" brand alarms before, and at that the only advice i can give is to get a whole new system or a replacement unit.
krook
Postby user99 » Thu Apr 13, 2006 7:44 am
krook wrote:your unit needs to be replaced. what brand of keyless entry/alarm system do you have?
My car doesn't have an aftermarket alarm. The remote for it only has lock/unlock/panic on the back. When you press the lock button, it only locks.. doesn't make any beep noise like I've seen before. The dealer said I do not actually have an alarm system...
but, one day I opened up my door and popped my hood, lock the doors back. I went and opened the hood and the frickin car started honking at me like an alarm would... so I'm not sure.
The doors unlocking when i turn the ignition doesn't bother me at all because the door lock buttons inside work properly and my remote works properly.
user99
Postby NeFaRiOuS_SLE » Sat Apr 22, 2006 8:37 am
Yeah the dealers talk out of the back of their ass, so therefore you DO have a stock alarm, but just the fact it doesn't beep is what confuses them (I have a 99 SLE too and it never beeps), but there ARE sensors in the hood, trunk and doors. Now if that isn't an alarm, I don't know what is anymore.
