SolaraGuy.com • View topic - DIY question: Spray Painting Interior
Postby x61485x » Tue Apr 11, 2006 4:23 am
Hey fellas,
I'm thinkin about spray-painting the 'wood trim', the center console, and part of the instrument cluster.
Any suggestions/pointers?
I'm thinkin...
Step one - sand down the glossy fake plastic wood lol
Step two - primer all the parts
Step three - spray the paint on
Step four - finish with some sort of gloss?
2006 G35 Coupe
1999 Solara SLE V6 Auto Silverstream (sold)
x61485x
Postby x61485x » Tue Apr 11, 2006 6:39 am
by the way,
how do i remove the wooden trim?
is it glued on? :(
2006 G35 Coupe
x61485x
Postby SleeperSolara » Tue Apr 11, 2006 7:38 am
x61485x wrote:by the way,
is it glued on? :(
The middle wood trim pieces on the dash is held on by clips.
As for the ones on the door they're glued in, but you can popped them off and re-glue them back on.
Postby Duffman » Tue Apr 11, 2006 9:40 am
If it's plastic, perhaps some of that Krylon Fusion will work? It actually bonds to the plastic, so instead of being "on" the plastic, it's in it.
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Postby krook » Tue Apr 11, 2006 11:49 am
Duffman wrote:If it's plastic, perhaps some of that Krylon Fusion will work? It actually bonds to the plastic, so instead of being "on" the plastic, it's in it.
i used that in my engine bay. on the plastic fuel rail cover with the Toyota symbol.
i attempted to sand down the shift gear selector surround plate and primer it, but in the end, i probably should have just used this Krylon paint. it bonds to the plastic so you wouldn't need to "prep" it with sanding or primer.
you can buy it at Wal-mart; check the can, it'll say that it can withstand high temperatures.
krook
Postby x61485x » Thu Apr 13, 2006 12:04 am
thanks everyone
time to go buy materials...
2006 G35 Coupe
x61485x
Postby TRD MCV20L » Thu Apr 13, 2006 12:12 am
Be sure to post up pics when your done!
TRD MCV20L
Postby djsaltine » Thu Apr 13, 2006 10:23 pm
x61485x wrote:thanks everyone
Whatever you do, be patient w/ the process. I completely re-painted the interior of my old Civic.
The 1st attempt, I wasn't patient. I had to re-gut and re-paint all over again.
Just be patient and very meticulous.
Good luck w/ it.
http://fairtax.org
djsaltine
Postby dude » Fri Apr 14, 2006 12:48 am
unless done very well or reversable, it might kill resale value....
dude
Postby SolaraFun » Sat Apr 22, 2006 12:26 pm
Good luck w/ it.
I agree to be patient with it. What color are you doing?
I also did the interior of my old Chevrolet Beretta Z26. It came out tight.
There is also a product called BullDog Adhesive that is for plastic and it allows the the paint to be drawn to it and stick to the plastic. Only minor gentle sanding is required.
Good Luck :D
~KT~
2002 Solara SE V6
+ 2 12" Sony Xplod Subs w/800w Amp
- Reverse Indiglo gauges
+ Carbon Fiber bezel & ebrake cover
"+" mesh grill
SolaraFun
Postby SolaraFun » Sat Apr 22, 2006 12:41 pm
http://www.bstuff.com/index.php?showtopic=2523&st=15
Here you go, highjacked from my other forum, but it works....
Go down about 5 posts.
I don't know if I ever got my pix on there, but if I find them, I will post 'em.
~KT~
2002 Solara SE V6
"+" mesh grill
SolaraFun
Postby x61485x » Tue Apr 25, 2006 7:48 am
Thanks for the help, it's DONE!
sort of...
I'll post pictures ASAP.
You guys were right when it comes to being patient. :(
I hated waiting for each layer to dry, and the sanding was a b.....
It's not exactly perfect, and I may go back and REDO it or apply more Clearcoat/Lacquer or whatever its called.
I painted the 2 plastic pieces of wooden trim on the doors and the ones on the dash. I also painted the plastic piece in the intrument panel and the center console including the piece around the shifter. My car's silverstream so I thought the silver would accent the interior much better than the 'wood' and black plastic. Just hope it doesn't look to 'ricey'. haha
2006 G35 Coupe
x61485x
Users browsing this forum: Google [Bot] and 35 guests
