SolaraGuy.com • View topic - changed valve cover gasket and a/f sensor today
Postby 90915-YZZA2 » Tue Apr 11, 2006 4:08 pm
Changed valve cover gasket and a/f sensor today for the first time. Used the instructions from Chilton manual (for the gasket) and tutorials from this forum (for the sensor). :D
Changing valve cover gasket is easy - it took me ~1 hour; the most important part is to clean the mating surfaces with acetone.
Changing the a/f fule sensor was also an easy job - I drove the car around for half an hour to really warm it up and thanks to that it came off more or less easily.
The dealership wanted to charge me $230 for changing the valve cover gasket + $280 for changing the a/f sensor incl. parts + tax.
I spent $14 for the gasket (bought at the dealership) and $154 for the a/f sensor (OEM Denso, direct fit - purchased online). I also changed the PCV valve - cost me $6 from the dealership. The tools were loaned from Autozone for free - torque wrench and oxygen sensor wrench set.
To sum it up, I saved $366 by replacing the parts myself. It feels AWESOME! :bday:
1999 Solara SE White Pearl I4
90915-YZZA2
Postby SleeperSolara » Tue Apr 11, 2006 7:04 pm
Congrats man.
Good job.
Postby 90915-YZZA2 » Tue Apr 11, 2006 8:13 pm
Thanks!
I've been lurking around this great forum for a long time and the fact that so many people did DIYs gave me confidence that I can do much of the maintenance myself without shelling out $$$.
:angel:
90915-YZZA2
Postby SleeperSolara » Wed Apr 12, 2006 7:20 am
90915-YZZA2 wrote:Thanks!
:angel:
Plus a another great thing is that when you work on your car you know nothin' can go wrong unless you read the DIY wrong too.
Postby 90915-YZZA2 » Wed Apr 12, 2006 8:26 pm
:angel:
Exactly! And you learn more about your car, too.
90915-YZZA2
Re: changed valve cover gasket and a/f sensor today
Postby Coconut » Mon Apr 17, 2006 12:52 pm
90915-YZZA2 wrote:Changed valve cover gasket and a/f sensor today for the first time. Used the instructions from Chilton manual (for the gasket) and tutorials from this forum (for the sensor). :D
I have already purchased the gasket off eBay and fixing to replace this weekend. Do you have a soft copy of the 'Chilton manual'?
Thanks
Coconut
Users browsing this forum: Google [Bot] and 17 guests
