SolaraGuy.com • View topic - Rear Thumping...
Rear Thumping...
Rear Thumping...
Postby SKYravefever » Sat Feb 01, 2003 5:58 pm
...and it's not what guys and gals think it's from. :wink: I've got 70K mi. on my OEM suspension, and am starting to hear thumping/popping noise when I hit a bump. It happens when I'm carrying two or more people in the backseat. I'm guessing that the rear suspension's giving way, and is causing the rubbing. What do you folks think? TIA.
SKYravefever
maybe shed some light?
Postby mattacosta » Sat Feb 01, 2003 9:22 pm
i had the same problem with my civic i use to had, i brought it to the local STS, and they checked it out ( i thought it was maybe the struts or something) they said that it was something with the back bumper. i only had 33k on it so it couldn't have been the suspension..
1999 Toyota Solara V6 SE
All Stock... For Now
http://www.cardomain.com/id/99solarama
mattacosta
Re: Rear Thumping...
Postby Flipside909 » Sun Feb 02, 2003 3:12 am
Corey,
Does your rear suspension feel bouncy? If so, it's time for new struts. 70k sounds about the right time. Push down on the back struts from the trunk or on each side...and see if the car rebounds. If it has excess bounce, your struts are out for sure.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
