SolaraGuy.com • View topic - MORE POWER AND GOING FASTER
Postby Twister » Wed Apr 12, 2006 8:43 pm
I NEED HELP!!!
WHAT CAN I DO TO MAKE MY STOCK 2001 2.2 SOLARA HAVE MORE POWER AND GET FASTER I NEED HELP!!!!! :o
STOP POSTING IN CAPS! It means you are yelling. -admin
JUST TRYING TO GET FAST
Twister
Postby SolaraBlue » Wed Apr 12, 2006 8:44 pm
you bought the wrong car... try finding a trd supercharger maybe.... do they make that for the 2.2? or nitrious, but itll destroy your engine most likely...
Postby dominoSLEV6 » Wed Apr 12, 2006 8:56 pm
You should actually be able to run a 50 shot of N2O, too bad you don't have the 2.4, it's a good engine for a 4 banger.
-chris
dominoSLEV6
Re: MORE POWER AND GOING FASTER
Postby DatSRBoi » Wed Apr 12, 2006 8:59 pm
Twister wrote:I NEED HELP!!!
Your car has potiential. its just how much you want to spend. They can beat V6 if done right.
Postby theprodigy79 » Wed Apr 12, 2006 9:00 pm
The 5SFE actually has some badass turbo kits available for it (the 2.2L actually has a WHOLE LOT more potential than the 2.4L)... I was in the process of doing research for my '93 Celica before I purchased my Solara and there are a TON of options available... Do a bit of internet research and I'm sure you'll find what you need...
theprodigy79
Postby TadS » Thu Apr 13, 2006 5:47 am
The 3/5S-FE is a remarkably durable, and simple, motor. It is one of the most durable in terms of longevity that I have ever seen. Granted the newer motors like the 2az have yet to really start seeing the high miles. Rippmods made a SC kit, and header for the motor both of top notch stuff, but they’re out of production. It's easy, as in the parts are known and acquirable, but expensive to turbo. There is a good amount of internals support available. It's a very expensive motor to build. If I was starting over, and had not spent the time and money on my current setup, I would just trade it in for a V6. Then I would supercharge it, do the heads, the fuel system, and a good aftermarket A/F tune. Still probably come out way ahead on the deal cash wise than trying to get the 5S to what a 1MZ makes in its factory form. If you are really stuck with the car / motor I recommend doing the head, and getting a mild turbo setup. If you need to go NA there is a stroker kit that will take it up to a 2.7. Anyway the stuff is out there, but none of it is cheap. Good luck on the project.
Please don’t type in all caps. It means that you are yelling.
TadS
Postby jhenty » Thu Apr 13, 2006 7:27 am
yea just custom turbo it, don't bother doing anything else because it will be a waste of time and money.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby Jon11582 » Fri Apr 14, 2006 10:07 am
If you got the 4cyl, dont worry about the performance and just enjoy your 32mpg. There is nothing that you can do that will be worth your time or money. (Even the rippmods, which I think was over $3k, only gets you slightly faster than a stock V6) If you want to "feel" more power, get an Injen intake, but it wont get you more power.
If you want power that bad and you still want a Solara, look to sell the 4 and buy one with a V6.
I personally have seen alot more done to 2AZs than the 5Ss, courtesy mostly to the tC community. Ive heard of tCs cracking the low 12s with just turbo work, but nothing even remotely close out of the 5S. Maybe that was all before my time though.
2000 Black Solara SE
Jon11582
Users browsing this forum: Google [Bot] and 17 guests
