SolaraGuy.com • View topic - shift nob
shift nob
shift nob
Postby woa_its_j3ff » Mon Apr 17, 2006 8:59 am
question.
I bought this shift nob but it's for manual, but i was wondering if i could install that on my car (auto) but this nob obviously has no overdrive button, can it be done? and how?
Postby rollaevo99 » Mon Apr 17, 2006 9:12 am
that's a tough one,but my friend did the same thing on his corolla but he relocate the OD button on his steering wheel, when I saw the red button on his steering wheel I thought he has NOS lol
Postby woa_its_j3ff » Mon Apr 17, 2006 9:21 am
rollaevo99 wrote:that's a tough one,but my friend did the same thing on his corolla but he relocate the OD button on his steering wheel, when I saw the red button on his steering wheel I thought he has NOS lol
any idea how to get the nob off my car in the first place?? (remember it's auto) and do i have to even put the Overdrive button or w/e back on ??
Postby krook » Mon Apr 17, 2006 11:54 am
woa_its_j3ff wrote:any idea how to get the nob off my car in the first place?? (remember it's auto) and do i have to even put the Overdrive button or w/e back on ??
there's 2 screws located on your OEM shifter. it's at the front of it (facing the engine bay) put your shifter in the "2" position and look at the front of it. once those screws are removed, you'll be able to slide the shift knob up. the shift button will pop out, so be sure to catch it.
the O/D button is simply a 2 wire hook up. you can relocate that anywhere you wish.
is your shift knob a screw on type with threads in it, or is there any screws that hold it on?
krook
Postby woa_its_j3ff » Mon Apr 17, 2006 12:04 pm
krook wrote:
well dont forget my car is auto, but unless if you mean the same thing?
Postby krook » Mon Apr 17, 2006 12:09 pm
woa_its_j3ff wrote:well dont forget my car is auto, but unless if you mean the same thing?
no. i mean the shifter that you bought. look inside of it. are there threads?
most shift knobs designed for M/T have threads on them so you can simply "screw" it on your OEM shifter. in YOUR case, you have a A/T, which would obviously pose a problem.
krook
Postby woa_its_j3ff » Mon Apr 17, 2006 12:12 pm
AHH ohh, no there are no threads.
Postby krook » Mon Apr 17, 2006 12:13 pm
since you bought a M/T knob, are there any holes in it so that you can attach it to your OEM shifter?
if there's no holes in it, you might have to drill some of your own.
krook
Postby rollaevo99 » Mon Apr 17, 2006 12:14 pm
just like what Krook said :wink:
Postby woa_its_j3ff » Mon Apr 17, 2006 12:19 pm
krook wrote:since you bought a M/T knob, are there any holes in it so that you can attach it to your OEM shifter?
there's 3 holes =) at the top before the nob thing.
oh yeah another thing, i know in order for you to drive (example: shifting from park to drive and vice versa..) you have to push in the button on top of the overdrive button, and push on the brake right, so what happens with all that stuff once and IF i can get this nob I bought to work?
Postby krook » Mon Apr 17, 2006 12:26 pm
to be honest. that knob won't fit.
the gear shift selector can only be moved if you depress that button to put the car in gear, whether it be PARK, REVERSE, or DRIVE.
krook
Postby woa_its_j3ff » Mon Apr 17, 2006 12:41 pm
ahh oh well,. i guesss ill just keept he nob as a souvenier haha.. oh well there goes 15 bucks down the drain. =\
Postby NeFaRiOuS_SLE » Sun Apr 23, 2006 12:08 am
I've seen some aftermarket A/T knobs with the button and the whole 9 yards, but I don't know if they are compatible with a Solara, though.
