SolaraGuy.com • View topic - flat black need clear coat???
Postby grsd03 » Mon Apr 17, 2006 6:10 pm
I don't know if I should post this in this forum but I have a 99 solara and I am going to paint the grill flat black, just wondering if i would need clear coat on it?? Also I know I have to sand it but what grit paper do I need to get a nice finish.
THanks
'99 SLE, sandstorm silver, auto, stock on 18's
grsd03
Postby Solorange » Mon Apr 17, 2006 6:16 pm
I clear coated mine. But I wanted mine shiny and I used black enamel. I cant remember what grit i used for sandpaper, but I used a rougher grit to get rid of the chrome, then a midgrad grit to get rid of some of the deep scratches, then like 1000+ grit (type of sand paper for wet sanding) I also used self etching primer after I sanded it to fill in anything I missed. You may want to sand in between primer coats very lightly to get rid of some of the roughness. Then sprayed like 4 thin coats of paint and 3 thin coats of clear. It turned out better than I thought it would being spray paint. Good luck to ya.
Postby SolaraT » Mon Apr 17, 2006 7:51 pm
Use rustoleum paint. I had mine metalic black once with no problems. If you want the gloss look just get the gloss paint and forget about flat black.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby SolaraT » Mon Apr 17, 2006 7:52 pm
Solorange wrote:I clear coated mine. But I wanted mine shiny and I used black enamel. I cant remember what grit i used for sandpaper, but I used a rougher grit to get rid of the chrome, then a midgrad grit to get rid of some of the deep scratches, then like 1000+ grit (type of sand paper for wet sanding) I also used self etching primer after I sanded it to fill in anything I missed. You may want to sand in between primer coats very lightly to get rid of some of the roughness. Then sprayed like 4 thin coats of paint and 3 thin coats of clear. It turned out better than I thought it would being spray paint. Good luck to ya.
Yup. many thin coats is key to sucess! :P
2007 VW GTI
SolaraT
Postby Solorange » Thu Apr 20, 2006 2:22 pm
I used the duplicolor paint you get at autozone. It worked good
Postby Assyrian » Thu Apr 20, 2006 2:35 pm
this is the best way to do it... in order to ensure a good result.
-Edgar
A noobie with an 02 SEV6 MTX
Assyrian
Users browsing this forum: Google [Bot] and 34 guests
