SolaraGuy.com • View topic - Dash/AC Lighting
Dash/AC Lighting
Dash/AC Lighting
Postby FLASH » Thu Feb 06, 2003 7:19 pm
On the way home from the pizzeria tonite, I went to turn up the heat, and realized I couldn't see it all that well. I have a stock Manual (not digital) entire Center Console, and its just the one section by the Temp Setting Knob and the one to the right that controls where the ventilation comes from that is darkened. I'm wondering if there is a light behind there that is burned out? How easy would it be to replace? Thanx.
==FLASH==
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby David » Fri Feb 07, 2003 7:52 am
I don't have an answer to your question but I have the same problem, sounds like in the same spot too. If you figure anything out let me know - David
David
Postby Jai_Jai_Binks » Fri Feb 07, 2003 8:39 am
That is/was the same problem with 5th Gen celica's, it supposed to be a bulb behind the console!
Re: Dash/AC Lighting
Postby Flipside909 » Fri Feb 07, 2003 9:54 am
FLASH wrote:On the way home from the pizzeria tonite, I went to turn up the heat, and realized I couldn't see it all that well. I have a stock Manual (not digital) entire Center Console, and its just the one section by the Temp Setting Knob and the one to the right that controls where the ventilation comes from that is darkened. I'm wondering if there is a light behind there that is burned out? How easy would it be to replace? Thanx.
==FLASH==
Haha, the same exact thing has happened to me recently. It's happening to me on the left portion of the HVAC controls. If you tap on it, it usually comes on. There's either a loose bulb or connection back there. I need to take it apart when I get time.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby 4banger » Fri Feb 07, 2003 10:49 am
I had the same problem with my 90 celica auto, the PRND21 wouldn't light most of the time. One time, leaving a rest stop I put it in 2 instead of D. I couldn't figure out why I couldn't get above 50.
Silver '99 Solara SE 4cyl.
4banger
Postby Ferrari_1299 » Sat Feb 08, 2003 12:49 pm
I also had the same problem but I tapped on it one time and ever since then it's been working.
1999 SE V6
Eibach Springs, Tokicko Struts, CF Hood, Custom Grill, Clear Corners, more to come...
http://www.cardomain.com/memberpage/275185
Ferrari_1299
Postby FLASH » Sat Feb 08, 2003 1:56 pm
I repeatedly tapped it, hit it, banged it, everything, and its still out :(
==FLASH==
FLASH
Postby Fenix » Sat Feb 08, 2003 5:12 pm
Flash,
if the lights in the AC/heater are burned out, you could replace them easily.
Just a moment ago, I was trying to change the light bulbs in there. I opened the AC/heater housing without any difficulty. However, these two lights in there are not 194.
They're the same kind as 194 bulbs but much smaller (like half an 194 size). They're the clear bulb with the green plastic cover.
I took couple of pictures of how to open the AC/heater housing. If you need, I'll post the pics up tomorrow.
btw, is anyone out there know the size of these light bulbs in the AC/heater housing??
Thanks
Fenix
Postby FLASH » Mon Feb 10, 2003 8:53 pm
How did you open it? Please post pics.
==FLASH==
FLASH
Postby Fenix » Mon Feb 10, 2003 9:12 pm
Here they are..
Assuming you have SE v6 2000 like mine.
after you take the dash out (normal way when you change your stereo head unit), you will see this:
To see 1 and 2, just take the knob and full toward you (very easy), you will have to open 1,2, 3, 4 and another 4,5 on the other side.
Then with this picture
Just put your index finger where 1 and 2 (once at the time) to pull up toward your head, then you will be able to access to the bulb in this pic
Just take the bulbs and pull out, color them with red Sharpie pen or do whatever you want with it.
Fenix
Postby Peter » Mon Feb 10, 2003 9:19 pm
just in case you dont know why the pictures dont work, its cuz you have to copy/paste the link. stupid pbase.
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby AzN_DrAgoN48 » Sun May 11, 2003 2:07 pm
the climate control knobs use 194 right?
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
Postby woshiagni » Sun May 11, 2003 2:38 pm
Fenix wrote:btw, is anyone out there know the size of these light bulbs in the AC/heater housing??
If they're the same as in the gen4 camry, then they're only available from the dealer AFAIK. They're about 2 bucks each, so handle them carefully. :D
You can try the following P/N's: (sorry, the invoice just says "bulb")
9001001002
9001001003
9098111018 <-- I think it's this one
These three P/N's are for the two bulbs behind the HVAC, the single bulb in the ashtray, and the single bulb for the PRND2L console panel.
woshiagni
Postby FLASH » Sun May 11, 2003 5:36 pm
This topic has been discussed before and theyre Sylvanias European Lamos No 2721...
==FLASH==
FLASH
Postby AzN_DrAgoN48 » Mon May 19, 2003 3:10 pm
where can you get those bulbs? my cig tray also burnt out. any idea about those lights?
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
