SolaraGuy.com • View topic - pcv valve; i-4 question
Postby socalisolara » Mon May 01, 2006 12:25 am
i was wondering how do you change pcv valve on a i-4. i saw tutorial for 6 but not for i-4.
socalisolara
Postby Jon11582 » Mon May 01, 2006 12:57 pm
Which I4
If its the 5SFE (gen 1 99-01) then its right on top of the valve cover, in the middle of the engine. Easy as yanking it out and replacing it.
2000 Black Solara SE
Jon11582
Postby socalisolara » Tue May 02, 2006 12:22 am
thanks for the input. another question, what is the advantage replacing the pcv?
socalisolara
Postby Turbosolara » Tue May 02, 2006 12:38 am
nothing, it just helps the engine to vent the pressure and recycle the dirt air back into the intake maniford.
Postby socalisolara » Tue May 02, 2006 12:48 am
if so, why do we replace it? and what would happen if i dont replace the pcv?
socalisolara
Postby Jon11582 » Tue May 02, 2006 12:03 pm
The PCV valve is spring loaded to only dump the corrosive and polluting fumes back into the intake when there is pressure. If its broken, its typically stuck shut
The only thing thats immediately apparent is you may have rougher idles. Over the long term, it can lead to bad emissions, and sludge buildup, and corrosion by the fumes remaining in the engine.
You can tell if a PCV valve is broken by shaking it. If it rattles, then the valve is opening and closing and it works. No rattle = stuck = broken.
Its such a cheap part, that you can change it every 15K for the hell of it.
Jon11582
