SolaraGuy.com • View topic - crap!!!... HELP! ASAP!
Postby woa_its_j3ff » Tue May 16, 2006 9:40 am
okay so here goes.
I was workin on the lara like usual.. and i was trying to change the license plate lights , so i got them out but the connectin was loose, so used a screwdrived to make the metal thingys closer so the bulb could clamp on better. after that, suddenly my taillights went out, including the license plate light bulbs.
BUT. my headlights were still ON.
so i had my bro step on the brakes for me and the taillights turned on, but when the headlight switch is on, the lights dont turn on. I found out the bulb is a 3157 (which is dual-filament). so i thought maybe it was just the bulb that was messed up, but so i got new bulbs for the brake/parking lights in the rear as well as new license plate bulbs, guess what.
They still do not work (still dont turn on). the brake lights/rear parking lights only turn on when i step on the brake, otherwise, if my headlight switch is in the on position, they will NOT turn on. so yeah the people at the Toyota dealership said maybe it's just the bulb (which i found out, it was not.. given that i BOUGHT new bulbs after this incident) .. or it could be a fuse , which is not true because i chekced all the fuses, nothing popped or burned out. Lastly, the people at AUtozone said it might be because of a short in the wiring? which they said can run up to 100 bucks to replace? and at the toyota dealership including labor costs, it would be about 200 something?? do you guys know exactly what might be wrong with my car? ... or?? anything? please help!!! any response is appreciated.
because I know this is just a ticket/accident waiting to happen as i drive this car at night, people who are folowing me in the rear, will NOT see my car cuz the lights wont turn on, so i need this fixed as soon as possible. thanks you guys, and help/response is really appreciated.
Postby krawzyazn » Tue May 16, 2006 9:51 am
have you checked the fuse lol I mean just change it even if it doent look popped
Postby theprodigy79 » Tue May 16, 2006 10:23 am
Sounds like you grounded it out and blew a fuse.
theprodigy79
Postby TadS » Tue May 16, 2006 11:37 am
Get out your continuity tester, DMM or whatever you prefer, and start trouble shooting the circuit. Sounds like you shorted to ground to me too. Check the fuses first for continuity (may as well hit the easy stuff first eh?), they should show little to no resistance, then get a wiring diagram checking for voltage at every connector along the way. That way you can pin-point where the problem is. Start with the easy connections, and have fun :D. You also might want to check for ground continuity/high resistance on the – side of the circuit. Grounding issues can create all kinds of fun taillight problems. Let us know how it turns out.
TadS
Postby krook » Tue May 16, 2006 11:54 am
did you check the fuse behind the coin box located to the left of the steering wheel...???
krook
Postby Turbosolara » Tue May 16, 2006 11:59 am
lol +1 for fuse
Postby Nyyankees3511 » Tue May 16, 2006 12:41 pm
I had the same problem, it was the fuse behind the coin box.
Nyyankees3511
Postby woa_its_j3ff » Tue May 16, 2006 12:55 pm
so most of you guys think it's just a fuse problem, and it needs to be replaced ? (the fuse behind the steering wheel column) ?
Postby cdeez » Tue May 16, 2006 1:02 pm
yeah just check the fuse..you have to pull out the coin holder door.
last standing...
Socalara...
cdeez
Postby woa_its_j3ff » Tue May 16, 2006 1:06 pm
cdeez wrote:yeah just check the fuse..you have to pull out the coin holder door.
So basically... it's like.. behind the coin holder thing on the left of the steering wheel column? (if so..) do i remove it with just force? or with like a screwdriver/tools?
Postby indiglosolara » Tue May 16, 2006 1:11 pm
Just open it.. and pull up.. for a little force and it shoudl come out...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby woa_its_j3ff » Tue May 16, 2006 1:49 pm
YAY it WAS the fuse, funny story, Toyota called sayin that it was the entire wiring switch that was messed up, sayin they needed to charge me about 200 bucks for all that crap.. haha.. liars -__-
Postby krawzyazn » Tue May 16, 2006 1:57 pm
woa_its_j3ff wrote:YAY it WAS the fuse, funny story, Toyota called sayin that it was the entire wiring switch that was messed up, sayin they needed to charge me about 200 bucks for all that schlock-schlock-schlock.. haha.. liars -__-
told ya it was the fuse
Postby woa_its_j3ff » Tue May 16, 2006 2:36 pm
krawzyazn wrote:told ya it was the fuse
yahh.... -__- still a noob in progress. but im so relieved you got no idea.. =) PHEW!!!
Postby krook » Tue May 16, 2006 5:17 pm
jesus fuckery. . .
krook
