SolaraGuy.com • View topic - v-vi-vibrations
v-vi-vibrations
v-vi-vibrations
Postby rreynolds » Tue May 16, 2006 9:03 pm
lately i've been getting some noticable vibrations and driver's wheel shaking. at higher speeds 70-80 mph its pretty noticable, and at low speeds there is a lot of movement. my two front tires are getting low on tread, the back tires are pretty good.
i'm thinking its just the tires, any input?
rreynolds
Postby Somedude » Tue May 16, 2006 9:13 pm
it could be more than just the tires, are the wheels loose? check them and take your car to a car shop so they can check it out. What you are describing sounds like a serious problem to me, I would take care of it asap.
p.s.: you should also do a search on this forum, there have been posts that relates to wheel vibrations and all.
Somedude
Postby sydemoid » Tue May 16, 2006 9:23 pm
Could be off balanced tires, or warped rotors as well
But definitely check the lugs, make sure they are torqued to spec, and the tire balance.... I get that done for 5 bucks each around here...
sydemoid
Postby Hsakuragi » Tue May 16, 2006 10:56 pm
check ur hub ring if they are aftermarket
Hsakuragi
Postby st.augsolara02 » Wed May 17, 2006 7:04 am
i had the same problem awhile back. a tire rotation/balance and alignment fixed it for probly 7-8 months but now its slowly coming back
So long Solara...Hello IS300!!!
New Project: '01 Autumn Sky Pearl IS300
* tien coliovers, 5% tint, SRT intake, HKS Carbon-ti exaust, 7" touch screen DVD, 2 12" Kicker Comp VR's
st.augsolara02
Postby rreynolds » Wed May 17, 2006 7:56 pm
thanks for the help - i put new tires on it and got an alignment, the ride is much better now. i'll keep an eye on it to see if it creeps back.
rreynolds
Postby SleeperSolara » Thu May 18, 2006 6:19 am
sydemoid wrote:Could be off balanced tires, or warped rotors as well
Actually the only way to tell if you have warped rotors is when you brake the steerin' wheel shakes like no other.
I think that is is your wheels not bein' balanced.
