SolaraGuy.com • View topic - Steering wheel freeplay.......
Postby SleeperSolara » Tue May 23, 2006 10:49 am
Well i just got my alignment done on Friday, and all four tires were out of line bad. :-?
Well i had teh steering wheel straight and was just messin' around and noticed there was some freeplay of the steering wheel when you turn it left or right, before the tires actually move. My bro's rental car which is an 06 Nissan Altima doesn't have any free play.
And my moms 2001 Sienna doesn't have any free play.....
So what you guys think????
Postby Jon11582 » Tue May 23, 2006 10:58 am
How did you test "freeplay"?
2000 Black Solara SE
Jon11582
Postby SleeperSolara » Tue May 23, 2006 11:34 am
Jon11582 wrote:How did you test "freeplay"?
Just had the steerying wheel striaght, and see how far it moved left or right before the tires/wheels/steering actually moved.
Postby SolaraBlue » Tue May 23, 2006 12:10 pm
did you get new tires?
Postby SleeperSolara » Tue May 23, 2006 12:30 pm
SolaraBlue wrote:did you get new tires?
Yeah i got Bridgestone Potenza G009's and i did get an alignment when i got the tires......
Postby SolaraBlue » Tue May 23, 2006 12:46 pm
it might be the fact that theyre brand new.....they might just need to be worn in a bit. did you get rims too?
Postby SleeperSolara » Tue May 23, 2006 2:06 pm
SolaraBlue wrote:it might be the fact that theyre brand new.....they might just need to be worn in a bit. did you get rims too?
Nope rollin' on stock ones right now. :(
Postby Nyyankees3511 » Tue May 23, 2006 3:38 pm
I dont know if i have the same problem but if im taking a turn on a highway at highspeeds and i hit a bump the steering wheel moves left or right??
Nyyankees3511
Postby Jon11582 » Tue May 23, 2006 5:56 pm
I thought maybe it had something to do with the stiffness (or softness) of the tire sidewalls.
I figure the altima might have stiffer sidewalls, but the Sienna, I doubt would have stiffer sidewalls.
Jon11582
Postby SleeperSolara » Tue May 23, 2006 7:19 pm
Well just checked dads' 98 Camry and the steering wheel has no free play either.
And how would the sidewall affect the steering wheel.
Postby NeFaRiOuS_SLE » Fri May 26, 2006 10:20 pm
SleeperSolara wrote:Well just checked dads' 98 Camry and the steering wheel has no free play either.
The more sidewall you have, the further the steering would go, but that's not the case in testing play in a parked car since my landlord has an '89 Toyota Pickup that doesn't have abnormal play (neither does his '04 Tundra or '91 Accord), and the sidewalls for the Pickup must be about 3", so I don't see how it'll affect anything on a test, but it DOES affect handling.
Postby SleeperSolara » Sat May 27, 2006 11:17 am
Well it just the steerin' part.
It fine but i don't like the free-play on the steerin' wheel.
Cause if you want to change lanes fast all you would have to do is move the steerin' wheel alittle bit and the car would move but in my case you have to move the steerin' wheel alittle more to have th ecar react.
