SolaraGuy.com • View topic - Bank 1 o2 sensor acting up?
Postby SC V6 » Fri May 26, 2006 11:06 am
I am getting a CEL for a heater malfunction for the o2 sensor.. so I checked the resistance, and it read 13 ohms, which is within spec.. whats the deal?
SC V6
Postby Sleeper » Fri May 26, 2006 4:07 pm
If you find out let me know, bcuz i have the same problem. Mine reads bank one sensor one, and I replaced it, but it came back on. Dont know whats going on...
SLEEPER...
Sparco Torino Seats, TRD Blower, Autometer Boost, Air/Fuel, and Tach gauges, DVD Touchscreen receiver, Carbon Fiber Reverse Gauges/Hood, 8K HIDs, Complete TRD Suspension, SPEC Stage 3 clutch & flywheel
Sleeper
Postby Hefty » Mon Jul 03, 2006 6:47 pm
On the v6 engine there are 2 - Bank 1 sensors and 1 - Bank 2 sensor. The Bank 1 sensors are located on the exhaust manifolds. The Bank 2 sensor is located on the aft section of the catalytic convertor. Sensor 1 is always going to be on the same side as Cylinder #1 in regards to ignition timing. So, in the case of the Solara v6, Sensor 1 is going to be on the firewall side of the engine. Its a tight fit and I would definently recommend a O2 sensor socket to help get a good hold of the sensor. Sensor 2 is going to be the easily accessed sensor next to the oil filter.
1999 Solara SE V6
2003 Nissan 350Z Track
Hefty
