SolaraGuy.com • View topic - Creaky Brakes?!?!?!?!?!?!!!
Postby solaratony » Mon Jun 05, 2006 10:03 pm
Okay, my brakes are making this obscene creaking noise whenever I press the pedal. I mean it's a LOUD "CREAK". Doesn't matter if I am coming to a stop, or pushing the pedal to get outta park. When Im sitting, the creak gets worse the harder I push. I THINK it's coming from the passenger side. I believe I have heard this noise before, but it was very light and only when I shut the engine off and then let off the brake. Today it was in to have the pass. side wheel bearing replaced. It was AFTER the service that it got worse. I know they have to take all that apart to get to the bearing, so I think they just agrivated the problem.
The mechanic suggested the the rotors may need to be turned. I would buy that if I only heard the noise while stopping. But it's all the time. He also mentioned that the front sway bar bushing was dried out. Don't know if he meant that as the cause or just mentioned it. I don't know what the FLUB is causing this noise, but since it happens when I press the pedal, it worries me.
PLEASE HELP!!!!!
99 SLE V6
solaratony
Postby Mr_Chunks » Mon Jun 05, 2006 11:15 pm
had the noise coming from my front passenger too
someone told me my rotors needed to be resurfaced or something. For me it only happens when im rolling to a slow stop. So Im buying a set of resurfaced brembos to replace my stockies and havin them take a look at the caliper and line when i take it in. ill let you know what the problem was.
Mr_Chunks
Postby solaratony » Tue Jun 06, 2006 10:55 am
Okay, Thanks.
99 SLE V6
solaratony
