SolaraGuy.com • View topic - Stage 4 clutch first impressions...
Postby Wang2k » Sat Jun 10, 2006 4:03 pm
I barely had time to get my clutch job finished up before the body shop took my car, I managed to put 300 miles on it the night before i took it in. I figured that would be a long enough break in especially since this clutch is rated for way way more power than i will probably ever be putting to it...
I will be using the clutch tho...as i just got a set of Mickey T ET Drags(10 inch wide) mounted on a set of offbrand(as far as i know, they have no words on them,) 15x8's with a crazy offset to them, they will go on the car when i take it to the track, or when im gonna race a seriously fast car on the street.
This clutch is incredible....it so instantaneous....let out of the clutch 1 inch and its already engaged...slipping is not a factor, i know because from a dead stop...i can rev the car to 6200 and drop the clutch, and it will wind all the way out smoke EVERYWHERE im talking choking coming through the ac vents thick RUBBER...and i know you are thinking yeah so any 5 speed can do that...im talking about starting out in second gear!
Wang2k
Postby DatSRBoi » Sat Jun 10, 2006 4:25 pm
Dam I wonder if the stock axle can handle such abuse.
Postby Wang2k » Sat Jun 10, 2006 4:41 pm
no i have replaced the long one about 10-15 times..no lie
Wang2k
Re: Stage 4 clutch first impressions...
Postby Grnarowana » Sat Jun 10, 2006 8:05 pm
[quote="Wang2k"]I barely had time to get my clutch job finished up before the body shop took my car, I managed to put 300 miles on it the night before i took it in. I figured that would be a long enough break in especially since this clutch is rated for way way more power than i will probably ever be putting to it...
This clutch is incredible....it so instantaneous....let out of the clutch 1 inch and its already engaged...slipping is not a factor, i know because from a dead stop...i can rev the car to 6200 and drop the clutch, and it will wind all the way out smoke EVERYWHERE im talking choking coming through the ac vents thick RUBBER...and i know you are thinking yeah so any 5 speed can do that...im talking about starting out in second gear![/quote]
Hey, did you have to change the whole fly wheel when you got your stage 4 cluctch? Or did you did the whole chnage thing?
Grnarowana
Postby Wang2k » Sun Jun 11, 2006 7:11 am
Im using the stock flywheel, i had it resurfaced
Wang2k
Postby SC V6 » Sun Jun 11, 2006 8:44 am
hmmmmm... *goes to get his hip waiters for all this bullshit*
SC V6
Postby Wang2k » Sun Jun 11, 2006 1:09 pm
who was bullshitting?
Wang2k
