SolaraGuy.com • View topic - 2002 Solara 16" Wheels for a 98 V6 Camry (OEM 15")
Postby camry noob » Fri Feb 14, 2003 2:16 am
Pls help.... Will 2002 16" Solara rims fit a '98 V6 Camry (OEM 15 x 6") or is the offset significantly different? I believe both are 5 - 114.3 bolt patterns.
If so, will I need to have computer/odometer/spedometer adjusted for the added 1" height
Thanks in advance
camry noob
Re: 2002 Solara 16" Wheels for a 98 V6 Camry (OEM 15&qu
Postby Yanks0114 » Fri Feb 14, 2003 12:47 pm
camry noob wrote:Pls help.... Will 2002 16" Solara rims fit a '98 V6 Camry (OEM 15 x 6") or is the offset significantly different? I believe both are 5 - 114.3 bolt patterns.
Thanks in advance
It should fit. The computer also won't need to be adjusted because the 15" should have a little thicker tire, but even if its off by 1" its really no big deal.
Postby Jai_Jai_Binks » Fri Feb 14, 2003 3:41 pm
If you are planning to do this..could you PLEASE email me some pic's...I was intrested in doing somethign similar...thanks!
Postby Flipside909 » Fri Feb 14, 2003 10:11 pm
Thanks in advance
It fits. As for the tire size being bigger, your speedo won't be thrown off that much beause all speedos are calibrated with a +/- 3 mph margin out of the factory.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Mixed info
Postby Camry Noob » Sat Feb 15, 2003 12:30 am
Thx for the replies. A dealer said that the bolt pattern/offset changed after the 2001 model year on the camry platform. Still trying to confirm the 16 x 6 5 - 114.3 bolt pattern info. Will advise when definitive info is confirmed.
Camry Noob
Mixed info
Postby Camry Noob » Sat Feb 15, 2003 12:37 am
Flipside, I am getting mixed msgs on this... dealer told me that the 2001 models and later had changed specs. I think mine are 15 x 6 5 - 114.3 bolts. Not sure what the new 2002 Solara specs are.
Can you refer me to a website perhaps. Thx
Camry Noob
Postby impactX » Sat Feb 15, 2003 1:04 am
The 2002 Solaras are still using the same rims.
I am pretty sure 2002 Camry is still on 5x114.3 bolt pattern.
impactX
Users browsing this forum: Google [Bot] and 33 guests
