SolaraGuy.com • View topic - solara's proformance
Postby cpcy333 » Sun Feb 16, 2003 5:07 am
hi i was wondering what is the spec on the solara v6 engine and how much hp can this engine handle? How fast can this car runs in a 1/4 miles? And what years did this car came in a 5-speed model? Any info will help and if there is any website that provide more info on this issues? Thanks
cpcy333
Re: solara's proformance
Postby Yanks0114 » Sun Feb 16, 2003 9:48 am
cpcy333 wrote:hi i was wondering what is the spec on the solara v6 engine and how much hp can this engine handle? How fast can this car runs in a 1/4 miles? And what years did this car came in a 5-speed model? Any info will help and if there is any website that provide more info on this issues? Thanks
The v6 engine is a 3.0L 200hp DOHC engine. The 5spd was available from 99-02. Since it has a high compression ratio 10.5:1, its hard to get the engine over 300hp at the crank reliably without a new set of heads. Jim from foreign affairs was working on this.
Postby cpcy333 » Mon Feb 17, 2003 12:56 am
hey yanks0114
i was wondering what did u mean by a new set of head?
do u mean to get it port and polish ???
cpcy333
Postby cdssolara » Mon Feb 17, 2003 2:21 am
cpcy333 wrote:hey yanks0114
I believe that he actually had a new set made, but they were also ported and polished. With all this, he ended up with 3.1 liters of displacement, rather than the standard 3. He did this in order to reduce compression, as Yanks stated. Now, he is able to safely run higher boost with his supercharger. He hasn't dyno tested it yet, but he is expecting to get over 300 hp at the wheels.
cdssolara
Postby 20SoLaRa02 » Mon Feb 17, 2003 3:38 am
as for your 1/4 mile question......let me save you sometime....a solara is not a sports car. It is not that fast so don't expect to be smoking a lot of people. BUT!!!!!!....if your stubborn and don't wanna face that fact and u really like the solara then it is possible to obtain a low 14 sec 1/4 mile......stock v6 stick should run u mid to high 15's depending on ur driving skills. Get a solara and join our family!!!!
20SoLaRa02
Postby Yanks0114 » Mon Feb 17, 2003 12:52 pm
Basically Jim from foreign affairs setup a core exchange. You send him your heads, and he sends them to a machine shop and has them ported and polished and i believe a few other things. It was a while ago that he posted this. He dropped his compression down to around 8:1, but its really not an option unless you extremely mechanically inclinded or you have a deep pocket.
Postby krazeee1707 » Mon Feb 17, 2003 7:18 pm
Wow, 8:1..nice. Has he ran it yet?
krazeee1707
Postby cpcy333 » Mon Feb 17, 2003 7:22 pm
hey cdssolara
with more than 300hp to the wheel do u know if he is breaking the 13 sec in the 1/4 miles??
and if i leave the engine stock how much h/p can it take without blowing it up. i was just thinking about putting juice into it???
thankz
cpcy333
Postby EricSol » Mon Feb 17, 2003 9:27 pm
I'm well over 300 crank (273fwhp). Its not hard to do, s/c@5.5 psi and headers. I bet I could do 300 crank at 4psi, thats only 255fwhp.
yanks0114 wrote:The v6 engine is a 3.0L 200hp DOHC engine. The 5spd was available from 99-02. Since it has a high compression ratio 10.5:1, its hard to get the engine over 300hp at the crank reliably without a new set of heads. Jim from foreign affairs was working on this.
2004 Pontiac GTO 408ci 535 whp all motor
1999 Solara 296 whp
EricSol
Postby Yanks0114 » Mon Feb 17, 2003 10:24 pm
cpcy333 wrote:hey cdssolara
thankz
Im assuming by "juice" you mean NOS. Its really not a great idea if you want your car to last. Personally i bought toyota for reliability, but NOS will greatly shorten the life of the engine.
Eric you are right that it might not be hard, but its expensive :wink: I also have an auto. Either way more power to ya. You car is awesome :D
Users browsing this forum: Google [Bot] and 19 guests
