SolaraGuy.com • View topic - V6 rear spark plugs?
Postby rrnfdr » Mon Jul 03, 2006 10:15 pm
Hi, Im a new owner, and I was just wondering if any of you have any tips for getting to the rear spark plugs on this motor. Ive done many tune ups on many types of vehicles, but I cant even see the plugs on this motor. Do you have to remove the intake?
rrnfdr
Postby lilmike2069 » Mon Jul 03, 2006 11:08 pm
no you dont have to remove anything... i did this a few weeks ago, took about an hour tops....
when facing the car, you can reach back on the left side and feel the back left plug wire (its mostly all feel, its hard to see) but just pull the plug wire out, and then put the appropriate socket WITH the extension but WITHOUT the wrench, in the hole and turn with your hand until it grabs... THEN put the socket wrench on. Its much easier to do if you put the wrench on after you've got the socket and extension in the hole first.
The rear middle and right ones are easiest from the driver side. Again, just feel for the plug wire and be patient. It may take a little struggle but you'll get it.
lilmike2069
Postby lilm » Mon Jul 03, 2006 11:41 pm
ya its easy.......just close your eyes and visualise :)
lilm
Postby SleeperSolara » Thu Jul 06, 2006 12:57 pm
Yeah not that hard.
And i think you will need to downsize your avatar.
Postby JAYDEE23 » Thu Jul 06, 2006 4:13 pm
JAYDEE23
Postby user99 » Thu Jul 06, 2006 5:10 pm
a six inch flexible ratchet is very very handy for the rear ones
99 Solara SLE V6, Automatic
user99
Postby rrnfdr » Thu Jul 06, 2006 6:21 pm
Okay I resized it and I gave you all a fresh view of it from the other side, is that more to everyone's liking? Im still tripping on the rear spark plugs though, mainly because I have really big hands, and I can destinctly remember how uncomfortable it was changing the plugs on some of the v8s I have worked on. Perhaps I am not skilled enough to attempt it without sight. I definately give props to all of you that can bust it on this ride though!
rrnfdr
Postby hskrsolara » Thu Jul 06, 2006 6:35 pm
Go get yourself a flourescent work lamp and sit it near the throttle body on the drivers side...this will help tremendously with finding the plugs from the passenger side.
I changed all of mine from the passenger side...just be patient and be prepared to really scrape up the hands and thumbs.
I know how you feel with the large hands...you wont be able to wear gloves, just bite your tounge and go with it. I would also recommend a couple of beers once you're finished. :)
hskrsolara
