SolaraGuy.com • View topic - Transmission
Transmission
Transmission
Postby ScottV » Mon Feb 17, 2003 9:31 am
I have a 99 Solara with 61k miles. i have new tranny fluid but it still does it. I noticed that at full throttle (automatic tranny) that when my car shifts into second the tranny will engage and go, then drop back a bit then start to go again. From an RPM point of view it will shift at 6200 then drop to say 3800 go a little then drop back to 3800 then go as usual. I am not sure what kind of problem this is. I think that the gears are fine and am guessing that the clutch might be wearing out.
Thanks
Scott
ScottV
Re: Transmission
Postby Flipside909 » Mon Feb 17, 2003 10:26 am
That's the torque converter working.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby ScottV » Mon Feb 17, 2003 5:51 pm
Is the torque converter going bad, because my car has never done this before until recently.
Scott
ScottV
Postby Flipside909 » Tue Feb 18, 2003 10:51 pm
ScottV wrote:Is the torque converter going bad, because my car has never done this before until recently.
Scott
When you got your tranny fluid replaced, did you get just a drain and fill or a full tranny fluid flush?
www.clublexus.com
Flipside909
Postby ScottV » Thu Feb 20, 2003 5:00 pm
Just a drain and fill.
ScottV
