SolaraGuy.com • View topic - My left side mirror was knocked out of my 2002 solara socket
Postby supercamsol » Wed Feb 19, 2003 7:28 am
while my car was parked---sombody hit the mirror and knocked it
so hard that it cracked the mirror and neck and bent the part where the neck attaches too-and my door does not close like it use to.
can you tell me where in the internet I can get parts that are not direct
from toyota because if I buy from toyota it will be expensive.
also is it possible to get a side mirror that swings in so as to avoid
that type of accident for a solara---it must be heated and electronic
and it folds----is that possible and where can I get it.
thank you for your help[/b]
supercamsol
Postby happy_aggies » Wed Feb 19, 2003 8:20 am
http://www.taprecycling.com/
Not really cheap either though.
happy_aggies
Postby Jai_Jai_Binks » Wed Feb 19, 2003 9:41 am
Don't know which forums, but someone bought a camry JDM mirror for their camry (because it folds automatically when same happened to them). My suggestion...go to a junkie and pull out LEXUS ES mirrors...On my ES..They fold (ok...not automatically but rather manually)..and they are heated! But I have no clue if it mounts on correctly or if the view then is SAFE! Good Luck!
Re: My left side mirror was knocked out of my 2002 solara so
Postby Flipside909 » Wed Feb 19, 2003 5:11 pm
supercamsol wrote:while my car was parked---sombody hit the mirror and knocked it
Try www.toyotaparts4u.com or www.partznet.com
No it's not possible to get a folding mirror on a Solara unless you get one from an ES like aformentioned. Y
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Flipside909 » Wed Feb 19, 2003 5:12 pm
www.clublexus.com
Flipside909
Postby Guest » Wed Feb 19, 2003 5:39 pm
thank you
toyota is selling the thing for 260
+75/hour to put it in
I found a place that will sell it for 170
but to put it in is still 75-80/hour
I will try the above,once again thank you all. :angel:
Guest
Postby Guest » Wed Feb 19, 2003 5:40 pm
thank you
Guest
