SolaraGuy.com • View topic - Temperature.....
Temperature.....
Temperature.....
Postby SleeperSolara » Wed Jul 19, 2006 4:14 pm
Gauge just spiked on me when i got home from work.....
I have a new radiator, new water pump, and the radiator fluid is topped in the reservior, and changed the thermostat when i first got my car......
Is that just normal???
It only spiked about a couple of mm's up.
Today was about 100 somethin'.
Am i just freakin' out or what????
Re: Temperature.....
Postby MCOjerry » Wed Jul 19, 2006 4:25 pm
SleeperSolara wrote:Gauge just spiked on me when i got home from work.....
My temp gague never moves from the same spot once the car is warmed up. Just stays there...
Maybe fan isn't coming on fast/often enough (thermostat).
Postby SleeperSolara » Wed Jul 19, 2006 6:13 pm
Well actually mine moves to about the middle of the number 2 of the gear selection in the gauge cluster.
Then it spiked when i was parkin' when i put the car in neutral, and did again today after i came home from gym.
It would spike to the middle of number "2" and "D".
Which is pretty high, then it would go back down.....
Is that normal????
Well i can hear my fans come on when i'm in netural.
They're louder than my dad's 98 Toyota Camry V6....
Postby Wang2k » Wed Jul 19, 2006 7:04 pm
maybe you have an air pocket. take the coolant cap off and crank the car. let it run with it off for a while to let any bubbles get worked out of the engine. Also your overflow tank shouldnt be completely full. It is there so the engine can barf it into there when you shut it off it should be filled to the line.
Ill bet you have air in your system
Wang2k
Postby toy4x4boy » Wed Jul 19, 2006 7:24 pm
Probably have a air bubble(s) in the system.
toy4x4boy
Postby Yanks0114 » Wed Jul 19, 2006 11:17 pm
Make sure not to take the cap off if the car is hot. Coolant could explode all over.
If you continue to have cooling problems, add some redline water wetter
Postby SleeperSolara » Thu Jul 20, 2006 6:32 am
Well when i installed the new radiator i thought i got all the air out.... :-?
Will see on Friday if takin' off the cap will work...
Probably will run the heater full blast to circulate the coolant.
Postby Jai_Jai_Binks » Thu Jul 20, 2006 8:36 am
EDITED: Both solara and camry stablize at 2for me. more so closer to bottom side of 2. When the sun is down then its lower than 2.
Postby SleeperSolara » Thu Jul 20, 2006 12:00 pm
Jai_Jai_Binks wrote:[quote="SleeperSolara]It would spike to the middle of number "2" and "D".
Both solara and camry stablize between 2 and D for me. more so closer to 2 when the sun is down and more closer to D if/when driving in day time.[/quote]
Pops Camry doesn't go as high as mine though. :-?
I wish my temp guage was like that. :(
It near the top of "2" on the cluster when drivin'.
Mine doesn't fluxwait when i drive onyl when sittin' in "N" when parkin' car in garage.
Postby Jai_Jai_Binks » Fri Jul 21, 2006 9:33 am
I would like to back-track what i previously stated.
My temps' gaugues if extended would match the bottom slide of "2" (and not D as i previously stated). In the evening, its below 2. PREVIOUS POST to be edited.
Postby Hsakuragi » Fri Jul 21, 2006 9:54 am
red coolant or green coolant?
Hsakuragi
Postby SleeperSolara » Fri Jul 21, 2006 11:05 am
Hsakuragi wrote:red coolant or green coolant?
Toyota Red Coolant always.
Postby user99 » Fri Jul 21, 2006 9:15 pm
my solara never burped, I had to drive it around for it to drink the fluid.
99 Solara SLE V6, Automatic
user99
