SolaraGuy.com • View topic - Correct Tire Pressure
Postby beloved » Thu Jul 20, 2006 9:57 am
I need the correct tire pressure for over-sized rims. Am I supposed to use the same tire pressure as the stock wheels? My car has 245/40/18 on it now. I bought the car this way two weeks ago, chrome wheels and body kit. That's why I'm clueless on this. Thanks in advance.
beloved
Postby Mole » Thu Jul 20, 2006 12:23 pm
the max psi is stamped on the tire.
look for it.
failing to do so can result in damage.
Postby SpikedMantis » Thu Jul 20, 2006 12:26 pm
Mole wrote:the max psi is stamped on the tire.
look for it.
Wait, what do you mean by that? Just don't go above it? Or should it be at it? The stock 16's say 44 is the max, but the manual says to keep it at 32.
This is the space where I should write something witty or clever, hoping to show some personality.
SpikedMantis
Postby solarasweetie » Thu Jul 20, 2006 1:32 pm
i think 32-35 is the range.
but i think its 35
<b>rock it 'cause its <i>stockkk...</i></b>....Image
solarasweetie
Postby Solarafreek » Thu Jul 20, 2006 1:39 pm
:lol: :lol: WOW :lol: :lol:
Solarafreek
Postby dvdchris45 » Thu Jul 20, 2006 1:41 pm
44 is when the car is has a full/max load. read carefully...
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby Jon11582 » Thu Jul 20, 2006 2:14 pm
Max Psi is the max a tire is designed to take, not what you should inflate to.
I've aksed this before, and I think the consensus was to add 2-3PSI for each plus size.
i.e. For stock 15s, its 29PSI, for stock 16s, its 32psi, for 17s, 34-35psi, and for 18s, 36-38psi. These are all cold inflation temperatures.
Just make sure NOT to exceed the max on the side of the tire, but I dont think any tire has a max PSI number that low anyways.
From memory:
Too little pressure = more contact patch, better dry traction, worse MPG, and for low profile tires, more risk of rim damage.
Too much pressure = less contact patch = worse dry traction, better MPG.
Too much or too little can lower your wet and snow traction, depending on the shape of the treads. Too much or too little will also increase the risk of tire blowout (Need to be around 30% over/under to be significantly higher risk).
2000 Black Solara SE
Jon11582
Postby MaxBoostSolara » Fri Jul 21, 2006 6:44 am
you can see what jon11582 wrote. i generally keep my tire pressure between 30-35psi.
MaxBoostSolara
My suggestion
Postby JMSinMaryland » Fri Jul 21, 2006 8:53 am
I keep my 16" winter wheels at 32 psi and 18" summer wheels at 35 psi.
JMSinMaryland
Postby Mole » Fri Jul 21, 2006 12:10 pm
each tire varies.
my s-03's had a max psi of 51.
just dont go above the max psi.
i kept mine at 48 psi, but again each tire is different.
