SolaraGuy.com • View topic - Auto Trans Fluid
Auto Trans Fluid
Auto Trans Fluid
Postby ChiTownSolara » Sun Feb 23, 2003 7:54 pm
i got 41,000 miles on my 99' Toyota Solara SLE, is their a recommended time frame or amount of miles that the system should be flushed and changed?? also, what goes in, Dexcool??
ChiTownSolara
Postby Yanks0114 » Sun Feb 23, 2003 8:13 pm
i beleive the trans fluid should be changed every 15k miles and flushed every 30-60k
Postby CrazyCraig » Sun Feb 23, 2003 8:24 pm
Make sure to use Dextron III. 5.0 qts. required for the 1MZ with auto.
CrazyCraig
CrazyCraig
Postby Peter » Mon Feb 24, 2003 2:36 am
what about for manual trans fluids? same?
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby CrazyCraig » Mon Feb 24, 2003 3:04 pm
The manual tranny on a 1MZ requires 4.2 qts. of API GL-4 or GL-5 gear oil with a viscosity of SAE 75W-90.
2.3 qts. are required for the 5S engine with manual tranny.
CrazyCraig
CrazyCraig
Re: Auto Trans Fluid
Postby Flipside909 » Wed Feb 26, 2003 11:50 am
ChiTownSolara wrote:i got 41,000 miles on my 99' Toyota Solara SLE, is their a recommended time frame or amount of miles that the system should be flushed and changed?? also, what goes in, Dexcool??
Dexcool is anti-freeze which is something you don't want to put in your tranny. You do need to use Dexron/Mercon NOT "DEXTRON"...either III or IV. It would be smart to get a whole tranny flush (not drain and refill) every 30k miles.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Flipside909 » Wed Feb 26, 2003 11:52 am
Peter wrote:what about for manual trans fluids? same?
Gear oil is correct. I change mine when the shifting gets rough. Every 30k or more often is a good reference to get it changed.
www.clublexus.com
Flipside909
