SolaraGuy.com • View topic - tried everything, cars still shaking
Postby hari-bhari » Sun Sep 03, 2006 7:18 am
so i got a couple of my bent rims repaired recently, and put brand new tires on. ive watched the guys at the shop mount and balance the wheel onto the tire, and according to the machine, they all balance out perfectly. they even did a road force test to adjust the high spots in the tire to the low spots on the wheel (im told that all wheels and tires have high and low spots no matter what).
so according to the machine, im in perfect balance. however, when driving, once i hit 70mph, the car shakes. its not coming from the steering wheel, but rather up through the body and i feel it in the seats. this makes me assume its the rear wheels and not the front.
is there anything that can be done at this point to stop the shaking? they insist that the wheels and tires are perfectly balanced. i saw them put each wheel and tire on the machine, and once the weights are added, the reading comes out to a perfect 0.00oz. however, when i view the tire spinning on the outer circumfrence, i can see it's not spinning perfectly round by a millimeter or two. the guys tell me this is normal, though. any solutions or options?
hari-bhari
Postby onefiend » Sun Sep 03, 2006 7:56 am
Sounds like you need an alignment. When I first got 18's for my gen1 I had the same problem. Had vibrations on the steeringwheel and body which was weird becuz the wheels were balanced. The guy at America's Tire Co. recommended an alignment and after that it went away.
2007 Camry SE V6
onefiend
Postby steve-o » Sun Sep 03, 2006 8:01 am
Drive less than 70 MPH. Problem solved. Your welcome.. :)
steve-o
Postby hskrsolara » Sun Sep 03, 2006 8:27 am
are you using hubcentric rings?
hskrsolara
Postby hari-bhari » Sun Sep 03, 2006 8:30 am
i think they came with the wheels...
the car used to run just fine before i bent the rims
hari-bhari
Postby slamd02ranger » Sun Sep 03, 2006 10:07 pm
If you hit something hard enough to bend rims, that can easily throw off your alignment.
1999 Solara 2.2 I-4 - Completely stock
2002 Ford Ranger 3.0 V6 - Bagged, 18's, & shaved. I keep it real clean.
slamd02ranger
Postby hari-bhari » Sun Sep 03, 2006 10:10 pm
got 4 wheel alignment plus balancing done, no luck :(
hari-bhari
Postby Nyyankees3511 » Mon Sep 04, 2006 6:33 am
Try putting on different rims. See if that does it.
Nyyankees3511
Postby ~Spadwaller~ » Mon Sep 04, 2006 6:41 am
you know theres a such thing as a high speed alignment
~Spadwaller~
Postby DrakkkarDarkbladE » Mon Sep 04, 2006 6:48 am
Check the wheel hubs, If they are broken the wheel might not rotate perfectly straight.
2002 SLE V6
"Great minds discuss ideas; Average minds discuss events; Small minds discuss people." - Eleanor Roosevelt
DrakkkarDarkbladE
Postby hari-bhari » Mon Sep 04, 2006 7:07 am
i have a hard time beleiving the alignment is affecting shaking
hari-bhari
Postby Nyyankees3511 » Mon Sep 04, 2006 9:36 am
Oh it can big time. Especially at higher speeds.
Nyyankees3511
Postby sbsolara84 » Mon Sep 04, 2006 10:28 am
i have the same prob. in my car right now.
but i had a loose linkage in the rear suspension, once that was fixed everything was ok.
the steering wheel still vibrates a lil at 70, but i think it's the bent rims. but new ones are coming.
if your steering wheel is vibrating, you need to get the tires balanced, make sure the front wheels aren't bent, and make sure nothing is loose in your suspension.
also check your tires.
if that doesn't work, take it into a shope and have someonese esle check it out.
what size tires and wheel are u running?
It's a pain, i've spent hundreds on balancing and aligning, nothing really worked. so i'm now trying new rims and tires.
...Ben
sbsolara84
Postby camry_101 » Mon Sep 04, 2006 11:44 am
i got the sam problem gonna do alignment and see wat happens!!!
2007 Ninja 500R stock
camry_101
Postby SleeperSolara » Tue Sep 05, 2006 7:14 am
Same wit me right now, i have one bent rims.
So i try to stay below 50mph.
But this Friday i'm goin' to have all 4 check for balanced and straightness, and see what happens.
Users browsing this forum: Google [Bot] and 20 guests
