SolaraGuy.com • View topic - 1mz trannies
1mz trannies
1mz trannies
Postby pythonjosh » Sun Sep 03, 2006 9:57 pm
I was wondering if there is a rwd tranny that would bolt up to the 1mzfe?
Since my car is totalled, thinking of putting the engine in the next car...
pythonjosh
Postby pythonjosh » Sun Sep 03, 2006 10:17 pm
After some more searching, some tacomas and pickups were made with the 1mzfe. However, it's a truck tranny with truck gear ratios. Would that make a 1mz swap into an AE86 not feasible?
pythonjosh
Postby made in china » Mon Sep 04, 2006 8:33 am
Hey, what happened to your car man??
Anyways, if you feel that Tacoma trannies are too tall, maybe you could get a shorter rear end too offset that.
Gettin' pirate eyed.......
2002 BSP SE V6 5 Speed
TRD RSB
5000K HID Headlights
3000K HID Foglights
Gen 1.0 Tails
Optitron Lexus Cluster
made in china
Postby pythonjosh » Mon Sep 04, 2006 9:23 am
made in china wrote:Hey, what happened to your car man??
http://www.solaraguy.org/viewtopic.php?t=28005
and
http://www.solaraguy.org/viewtopic.php?t=27989
You need any parts?
Rear end meaning the rear diff? I dunno too much at all about those and aftermarket or modification of gear ratios. You should stop by and check out the damage. I'm in Northgate.
pythonjosh
Postby Jon11582 » Mon Sep 04, 2006 12:22 pm
No 1MZ in the AE86. The problem is the 1MZ mounts transversely, and wont work a driveshaft that is required with a traditional Front engine/rear wheel drive platform.
The only RWD platform that would work with the 1MZ is the old MR2, since the engine is mounted midship, so it would also be mounted transversely for RWD, BUT it wouldnt be direct bolton to the existing tranny.
2000 Black Solara SE
Jon11582
Postby Wang2k » Mon Sep 04, 2006 1:40 pm
if you use a rwd tranny then you dont have to mount it transversely.
find a tranny or find a way to make one fit, then its just like every other swap, make motor mounts, a transmission crossmember, and a custom driveshaft. modify the harness to fit, plumb a fuel line, get headers made(the biggest ouch) and your done! i think it would be cool as hel
Wang2k
Postby pythonjosh » Wed Sep 06, 2006 2:32 am
Wang2k wrote:if you use a rwd tranny then you dont have to mount it transversely.
Crap I forgot about the headers. Gorramn thats gonna suck. Still scoping out transmission possiblities, don't really like the idea of a truck tranny at all.
pythonjosh
