SolaraGuy.com • View topic - What kind of gas are you guys putting in ur Solara?
Postby Dawgz » Tue Sep 05, 2006 11:40 pm
In a stock Solara, what are u guys putting in? i usually do regular to plus, and sometimes Super.
but mostly regular =\
Is that bad for the car?
Postby made in china » Tue Sep 05, 2006 11:45 pm
regular is fine.
I run Premium all the time, in my particular experience, my V6 with 5 speed gets about 500 miles to a tank with Premium, and about 400 to a tank on Regular. So, actually the Premium is probably cheaper overall in my car, but even if it wasn't I still like the fact it goes so long on one tank.
BTW, the car will run fine on whatever grade you choose, I think with the V6 though, the ECU can tune in the car more efficiently using premium.
Gettin' pirate eyed.......
2002 BSP SE V6 5 Speed
TRD RSB
5000K HID Headlights
3000K HID Foglights
Gen 1.0 Tails
Optitron Lexus Cluster
made in china
Postby solow1605 » Tue Sep 05, 2006 11:56 pm
i run diesel foo
2003 Anniversary Edition z06. Black on black...seeexxy
solow1605
Postby made in china » Wed Sep 06, 2006 12:05 am
that gives you mad tork
TRD RSB
3000K HID Foglights
Gen 1.0 Tails
made in china
Postby slamd02ranger » Wed Sep 06, 2006 7:11 am
I use 87
1999 Solara 2.2 I-4 - Completely stock
2002 Ford Ranger 3.0 V6 - Bagged, 18's, & shaved. I keep it real clean.
slamd02ranger
Postby Strider327 » Wed Sep 06, 2006 8:29 am
91 on all my cars. High compressions engines always need higher octane. Plus it'll burn cleaner. Remember you get what you pay for in terms of quality.
Strider327
Postby Sebas007 » Wed Sep 06, 2006 8:38 am
Strider327 wrote:91 on all my cars. High compressions engines always need higher octane. Plus it'll burn cleaner. Remember you get what you pay for in terms of quality.
Amen !
I used to get 91 or 94 octane...
US fuel is so cheap...if I do the conversion in US gal I would pay
Knowing that...
US gal = 3.8 liters
CAD/USD = 0.9
3.27USD$/gal 87
3.83USD$/gal 94
Postby Sap Z » Wed Sep 06, 2006 8:38 am
wait ---
higher grade equals higher mpgs?
if true i might have to try it out..
SapZ
V6 SE DWP
Sap Z
Postby LatinDragonXJC » Wed Sep 06, 2006 9:06 am
super all the way, it lasts longer because of the higher octane, the more octane = more bang , and more bang means less fuel to do the same job. Bang for your Buck.
LatinDragonXJC
Postby made in china » Wed Sep 06, 2006 9:21 am
Sap Z wrote:wait ---
I don't know if it'll work on all cars. Try it on yours, then do the math. I am sure you'll get a few more miles on a tank, then you can see if the cost savings is worth it. Remember, Premium in the V6 will generate a little more power too....if that's worth anything to you.
Also, this isn't true for all cars. Our 97 Max SE is a AT, and it pretty much gets 23-24MPG in city whether we use 87 or 91. However, the engine pings a bit (almost 200K miles, she's tired) more on lower octanes when loaded up, so we try and keep at least 89 in that car...just depends on gas prices and my mood.
TRD RSB
3000K HID Foglights
Gen 1.0 Tails
made in china
Postby Turbosolara » Wed Sep 06, 2006 9:36 am
well if you have high compression and you put lower grade of fuel, it will cause detonation in which result retarded timing = run rich = less power. so it will decrease fuel efficiency.
but how high is high compression? i am not too sure but i think 10:1 is definately consider as high compression. just try different fuel on your motor and see what it likes.
Postby Grnarowana » Wed Sep 06, 2006 2:53 pm
Using Premium and getting 500 for full tank also.
Grnarowana
Postby briantek » Wed Sep 06, 2006 3:09 pm
What about for my 4 cylinder 2003?
briantek
Postby platypusfetch » Wed Sep 06, 2006 3:19 pm
i run 91 up here in Canada, and call me "Rainman," but i never let the tank go below 1/4 remaining. I consistantly see 600KM/ tank of 91 octane. (Of course that being said, i have never tried a lower grade. Owners manual recommended 91 so it gets 91. Some staunchy guy in a white lab ccoat with more education than me came up with it. I figure it was for some reason i don't know, but i will trust him anyways)
5S MT
SE, V6
platypusfetch
Postby onefiend » Wed Sep 06, 2006 3:44 pm
running 91 octane on the 2GR. They should consider bringing 93 octane back.
anyone looking forward to pumping E85 gas in your tanks in about 20 years?
2007 Camry SE V6
onefiend
