SolaraGuy.com • View topic - 2000 SLE Tire, Brake Pad, and Rotors Recommendations Wanted
Postby danh » Sat Sep 09, 2006 5:06 pm
Can you please direct me to the relevant threads. I am sure these have been discussed before. Will be replacing soon. Do I go OEM? My past experience with other cars tells me to do so. But would like some input. Thanks. By the way, what is the OEM tire brand 205-60-16?
danh
Postby SolaraBlue » Sat Sep 09, 2006 5:30 pm
oem tires= bridgestone potenza RE92
Postby Jon11582 » Sat Sep 09, 2006 5:31 pm
Best recommendations.
Brake pads go OEM, or if you want more stopping power, but more dust and less brake life, go with Hawk HPS pads.
Rotors go Brembos (no slots, no drills)
Tires, DONT go oem. The OEM tires are pretty bad. I cant really give you a recommendation. I used to use Kumho Ecsta 716 HP4s, great tires and cheap to boot but the sidewalls are weak, I kept getting bubbles in them. Just go to www.tirerack.com and find out whats good.
2000 Black Solara SE
Jon11582
Postby TMMK Toy » Sat Sep 09, 2006 6:49 pm
Might also help if you mention what tire size you're running. What is available varies from sizes. Generally though the wider and lower profile, the better your options for high grip tires. I'd say if you can get em go with BF Goodrich Gforce T/A. Great dry tire and closest you'll get to a race tire for the street. Downside will be noise and short tread life and not the best for the wet, but if you're all about handling, way to go if you can get them. Goodyear Eagale F1GSD3s are great too. Great in the dry and wet, but useless in the snow.
For brakes, like the man above said, go with a more aggressive pad and just regular brembo rotors should be good. Also if you want, go with SS lines and replace your fluid with something that is high temp. boiling point. Not sure what's compatible with ABS systems. Never owned a car with ABS.... yet.
TMMK Toy
Postby hskrsolara » Sat Sep 09, 2006 7:51 pm
i have heard great reviews for the yokohama avid tires...give those a look.
hskrsolara
Postby woa_its_j3ff » Sat Sep 09, 2006 8:22 pm
what about Nitto tires? or YokohamaA??..
Postby Nyyankees3511 » Sat Sep 09, 2006 8:27 pm
I use discounttiredirect.com sometimes. I just bough Yokos avid h4s and i could be happier. It was 280 shipped for all four, plus they have a 500 treadwear rating and aa traction. Also they are very quiet and good handling tires, i highly recommend.
Nyyankees3511
Postby anttarz » Sat Sep 09, 2006 8:42 pm
Brembo plain rotors and oem pads, i did mine last month. Arent the stock tires 205/55/16?
anttarz
Lol
Postby JMSinMaryland » Sat Sep 09, 2006 10:08 pm
Shh, don't tell him about the Avids. It's the best secret in the tire industry. If Yoko starts realizing what they have their going to jack up the prices.
JMSinMaryland
Postby TMMK Toy » Sun Sep 10, 2006 8:56 am
Stock tire size I believed were 205/65R15s
TMMK Toy
Postby Jon11582 » Sun Sep 10, 2006 11:35 am
For Gen1/1.5, stock is 205/65/15 for 15" steels and optional alloys on the SE, and 205/60/16 for 16" alloys, optional on SE and standard on SLE.
Jon11582
