SolaraGuy.com • View topic - OEM Anti-Theft system
Postby rec » Thu Sep 28, 2006 2:16 pm
Anyone got techinical information regarding the anti-theft system on a 2002 solara ? I bought the car used and never got the remote so i asummed it didnt work or something... ive always seen the light blinking when i turn off the car but didnt think much of it. Im trying to get the system turned off or something because right now the car wont start because of it i think.
Mine is black.......
rec
Postby krook » Thu Sep 28, 2006 2:22 pm
i don't think OEM systems come with a starter kill option simply because we already have a transponder chip in the key.
if you're tryin' to start the vehicle with the key and it doesn't start, it's probably something else.
does it crank?
krook
Postby rec » Fri Sep 29, 2006 11:27 am
my key doesnt look like it has a chip ..... ? its an 02 sle
rec
Postby krook » Fri Sep 29, 2006 12:27 pm
i have a 2000 SE and mines comes with one. chances are, you've got one. when you try to crank the starter, does the horn honk?
krook
Postby rec » Fri Sep 29, 2006 12:46 pm
i dont even have the car at my house its been with this crappy machanic that cant figure out why it wont start after he rewired the whole car. He thinks its the anti theft system. Im just going on what hes telling me
rec
Postby Sol-Toy » Fri Sep 29, 2006 2:38 pm
I had/have a similar issue with my car. The previous owner did something to the OEM keyless entry system. I assume that they installed an aftermarket alarm and stripped it out once they sold the car. There is no chirp or honk.
Anyways, the car won't start if you accidentally arm the car while your inside the car. Sometimes it will start but the flashers kick in. Very strange. I have to "unluck then re-lock then unlock" inside the car, then again from the outside. I still haven't figured out the proper combo but that elliminates the issue until I accidentally arm it while inside the car again.
pre-owned cars with aftermarket alarm systems are a real pain in the a$$
2013 WRX Wagon Premium in crystal black silica - current
2012 RAV4 S - Wife's
2000 Solara 1mz - sold after recording 160k mi
https://www.instagram.com/andygriesemer/
Sol-Toy
Postby krook » Fri Sep 29, 2006 8:11 pm
Sol-Toy wrote:I had/have a similar issue with my car. The previous owner did something to the OEM keyless entry system. I assume that they installed an aftermarket alarm and stripped it out once they sold the car. There is no chirp or honk.
toyota factory systems disarm with the unlock of the driver's door (2 times).
if the parking lights are flashing at you (meaning that the "alarm" is triggering) unlock the doors with the key via driver's keyhole. turning once unlocks the driver's door, turning twice unlocks the rest and that usually shuts the system off.
krook
Postby Nyyankees3511 » Sat Sep 30, 2006 8:05 pm
If you want to make sure if you have oem alarm, head to the toyota dealer and give em your vin and they can tell you. I can tell you that the oem will not cut anything out, you should at least get a crank.
Nyyankees3511
