SolaraGuy.com • View topic - 70K miles
70K miles
70K miles
Postby Dawgz » Sun Oct 01, 2006 10:54 pm
i baught the 00 solara with 42k miles and now ive just gottn to 70K miles.
All i have been doing is regular oil changes as 3k miles.
what should i be doing now that i got to 70K?
Postby TMMK Toy » Mon Oct 02, 2006 6:50 pm
big service interval isnt till 90k when you wanna do the timing belt, water pump, all main seals, and tune it up as well. Maybe for 60k a transmission service of some kind may be involved, like changing the fluid. Also, ever replaced your air filter? If you havent its defiently due.
TMMK Toy
Postby Jon11582 » Mon Oct 02, 2006 6:58 pm
Spark Plugs, Coolant change, air filter change
2000 Black Solara SE
Jon11582
Postby Dawgz » Mon Oct 02, 2006 9:00 pm
air filter was changed at like 55K (k&N) havnt cleaned it yet...will do this weekend.
coolant change? omg those things cost a crap load....ok i will look into it tho.
Thanx for ur replies.
Postby Sentinel » Mon Oct 02, 2006 9:06 pm
No preventative maintenance bill will look too expensive once you see how much it costs NOT to do it.
My Haynes manual sez to check valve clearances at 60k, but I thought this was unneccesary with hydraulic lifters. Anyone have this service done?
Sentinel
maint
Postby NRDriver » Mon Oct 02, 2006 9:21 pm
i replaced the spark plugs at 60 k. toyota sayed thats what they are rated at. i noticed a big difference once they were replaced. make sure you replace them with the deno's
NRDriver
