SolaraGuy.com • View topic - rear wheel question
rear wheel question
rear wheel question
Postby woa_its_j3ff » Thu Oct 12, 2006 7:14 am
So yesterday I wanted to rotate my tires front to back. Front wheels came off easy, just remove lug nuts, but then when it came to the rear wheels, i can take off the lug nuts but it looks like it's stuck the axle or something, neither of the rear wheels come off..
so. how DO you get the rear wheels off??
- Jeff.
Postby ---CAMRAZY--- » Thu Oct 12, 2006 8:10 am
Con Huevos??
Postby Jon11582 » Thu Oct 12, 2006 8:38 am
I4 or V6?
Mine was stuck to my rear drums, I dont know if rear discs have the same problem.
How I got it done was to bring it to wheel shop, where they can put it on a lift, take off the lugs, and mule kick it until it comes off. I gave them 10 bucks when it was all said and done.
I don't suggest you try this without a lift.
If you rotate your tires regularly, you shouldn't have this issue in the future.
2000 Black Solara SE
Jon11582
Postby Sentinel » Thu Oct 12, 2006 9:25 am
Just give 'em a lil' kick on the rubber. (make sure the car is secure)
You might try driving around to heat the brakes up, then trying to remove them?
Sentinel
Postby ThatVietGuy » Thu Oct 12, 2006 10:00 am
I also suggest that you kick the top of the tire, but like Sentinel said, MAKE SURE IT'S SECURE. I had to do it on mine a little while ago.
ThatVietGuy
Postby rollaevo99 » Thu Oct 12, 2006 10:05 am
CamrySE-soCALlara wrote:Con Huevos??
LOL
Postby woa_its_j3ff » Thu Oct 12, 2006 10:11 am
^lol .
Thanks guys. too bad I dont have a lift, maybe ill just wait til when i get my rims in the spring.
Postby Ford_Fixorrepairdaily » Thu Oct 12, 2006 10:35 am
Same problem here. Just make sure your jack really secure. Then get underneath and give it a Chuck Norris round house kick. I kicked mine about 5 times before it came off. If you bring it to the shop, they'll do the same :D
Postby Jon11582 » Thu Oct 12, 2006 10:41 am
I dont suggest you do this with a jack, or anything less than a lift. If your car falls off the jack, its bad bad news. Especially if a wheel falls off too. Then you'll be sitting on wrecked rotors.
Your not even supposed to loosen your lugs when your on jacks, so theres no way you should even consider kicking your wheel while your on jacks.
Just go to the shop and have them do it.
Jon11582
Postby lightear » Thu Oct 12, 2006 12:51 pm
Would WD-40 help?
lightear
Postby Ruski » Thu Oct 12, 2006 1:03 pm
had the same problrem i jsut gave it a hard kick and it came lose
Postby woa_its_j3ff » Thu Oct 12, 2006 4:33 pm
yeah problem is i dont have a jack. only spare tire jack lol... =( ... so i guess im SOL .. time for shop, I think?
Postby facevedo17 » Thu Oct 12, 2006 4:36 pm
Take it to the Shop up in the east winter is coming were not gonna be working on them in the Cold IMO ......but that usually works give it a good licking and it comes right off " make sure u are secure " : )
facevedo17
Postby Ruski » Thu Oct 12, 2006 6:28 pm
i got to rotate mine and put on suspension before winter hehe :)
wheels
Postby NRDriver » Thu Oct 12, 2006 11:10 pm
LOL. just put that biznizzle on jackstands and use you big boy muscles or ever a tanker bar yo. i will come loose
NRDriver
