SolaraGuy.com • View topic - EGR
EGR
EGR
Postby rossman945 » Sat Oct 28, 2006 11:55 am
Well, I got a cel so I got it scanned, and it said that my EGR valve was misfunctioning. The only thing I know about this is it has something to do with emissions. Toyota wants 213 for the part and 150 for the install. Does anyone has any input on this. Thanks,
Ross
rossman945
Postby onefiend » Sat Oct 28, 2006 2:25 pm
try and see if you have any pinched or clogged hoses, you can clean out your EGR valve yourself. If that doesn't work buy the EGR valve and install it yourself. The CEL comes on either cuz the valve is stuck open or closed from excess carbon build up. It's an emissions thing.
I had this problem twice in my old gen1 Solara, the first time at 55,000 miles I had Toyota clean out the system and change the valve, they charged me $260 and they said I also needed my fuel injection cleaned, lol for another $110. I cleaned my fuel injection myself but at 74,000 miles I get the same CEL for the EGR, I ended up selling the car without getting it fixed.
2007 Camry SE V6
onefiend
Postby rossman945 » Sat Oct 28, 2006 7:05 pm
Wheres the EGR valve located?
rossman945
Postby Turbosolara » Sat Oct 28, 2006 8:06 pm
try to use seafoam first. search on internet for seafoam and EGR, you will find tons of examples
Postby Eye8Pussies » Sun Oct 29, 2006 12:13 pm
just get rid of your egr system- no more problems and better performance.
Postby rossman945 » Sun Oct 29, 2006 12:38 pm
good idea. but wouldn't the CEL be on always?
rossman945
Postby Eye8Pussies » Sun Oct 29, 2006 3:23 pm
nope.
all you need is a resistor to trick the ECU into getting a false (and always perfect) CEL temp sensor reading.
one less thing to worry about on the long road to top performance ;)
Re: EGR
Postby bronzemaxell » Sun Oct 29, 2006 7:45 pm
rossman945 wrote:Well, I got a cel so I got it scanned, and it said that my EGR valve was misfunctioning. The only thing I know about this is it has something to do with emissions. Toyota wants 213 for the part and 150 for the install. Does anyone has any input on this. Thanks,
Ross
if you get odb 2 codes such like P0402, chances are, the ecu complain about egr, if you have a V6 which is located right after the throttle body, on the plunem intake, 5 of 10mm screws to hold it. probably take around 10 or 20 minutes of labor, egr valve cost around $160 to $180 at online toyota dealer and two gaskets less than $2., but if dealer charge $150 for labor, probably it is over priced unless they performing other preventive maintainance also.
bronzemaxell
