SolaraGuy.com • View topic - fuel solutions
fuel solutions
fuel solutions
Postby rec » Wed Nov 01, 2006 1:02 pm
ive always seen those fuel solutions at the auto store and i was wondering if their any good. What brand and what type should i buy ?
Mine is black.......
rec
Postby ~Spadwaller~ » Wed Nov 01, 2006 1:06 pm
Additives = bad
100% petro Seafoam = good
my $.02
~Spadwaller~
Postby rec » Wed Nov 01, 2006 2:03 pm
how do i use the seafoam ? Sounds like a good product so ima try it out , so i just pour it into my gas tank ?
rec
Postby ~Spadwaller~ » Wed Nov 01, 2006 2:13 pm
I do half in the PCV valve and the other half in a half tank of gas. If you do the PCV valve it cleans the throttle body but smokes like the car is on fire so do it in an open area like a big parking lot also I do it when I'm due for an oil change too.
~Spadwaller~
Postby rec » Wed Nov 01, 2006 3:02 pm
wheres the PCV valvle ? sorry :oops:
rec
Postby bassthrive » Wed Nov 01, 2006 3:39 pm
seafoam is great. im not sure about the pcv valve though. you are pouring the seafoam right onto the lifters under the cam cover. and it is only on one side. i do this.
1/3 in the gas tank (cleans the fuel injectors, eliminates any water in the gas tank)
1/3 in through the oil filler
1/3 in through the brake booster vac line (this cleans the combustion chamber, intake/exhaust valves and some of the intake plenum, but not as good as a throttle body spray)
whenever you put the seafoam in the oil, you will want to change the oil and filter asap.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby rec » Thu Nov 02, 2006 8:43 am
should i put the 1/3 of seafoam into my gas tank with a full tank or with half ?
rec
Postby Jai_Jai_Binks » Thu Nov 02, 2006 10:46 am
If all your doing is 1/3 in the gas tank then IMO even a consentrate STP fuel injection cleaner is suffice in the gas tank.
I normally do the 1/3 on the tank and 1/3 on the oil every year. If i could do the 1/3 on the brake/bster lines i'd do it. I'm pretty sure my homeowners association will cite me for overexessive smoke. heck, they are pretty bad...we already got a notice for haloween yard signs on nov 2nd!!!
Postby Midias » Thu Nov 02, 2006 11:18 am
I do seafoam in 2 cans 1 in the manifold 1/3 in the oil and 2/3 in the fuel.
I also like lucas fuel treatment.
Postby slamd02ranger » Fri Nov 03, 2006 12:23 am
I've used that stuff and it did absolutely nothing for my vehicle.
1999 Solara 2.2 I-4 - Completely stock
2002 Ford Ranger 3.0 V6 - Bagged, 18's, & shaved. I keep it real clean.
slamd02ranger
