SolaraGuy.com • View topic - Tailights and Signal lights OUT
Postby LatinDragonXJC » Tue Nov 07, 2006 5:58 pm
I just got my car back from the auto body shop after bringing it back for a second time for paint issues and them messing up my corner lights. Now I took a good look around my car with all the lights on.
My corner lights dont turn on (but they do signal). And my tailights dont turn on while in drive, but the signal and brake light works. I tried changing the fuse, no result.
Anybody have an idea what it is or has it happened to one of you? I just got a ticket last night because of it (and that brought it to my attention).
LatinDragonXJC
Postby woa_its_j3ff » Tue Nov 07, 2006 6:04 pm
not sure if main wiring harness may be the problem. when i had a problem like that of yours on my car it turned out to be the fuse...
Postby NeFaRiOuS_SLE » Tue Nov 07, 2006 9:28 pm
woa_its_j3ff wrote:not sure if main wiring harness may be the problem. when i had a problem like that of yours on my car it turned out to be the fuse...
Yeah, what he said... But keep in mind that there are some times that there are more than one fuse for each component; it was the most frustrating thing when I noticed that happen in my old car... Without a voltmeter, and had to pluck out EVERY fuse and check it until my malfunctioning retractable antenna until I came across DOME (as in dome light).
Postby ron33030 » Tue Nov 07, 2006 9:29 pm
its the ground
ron33030
Postby LatinDragonXJC » Wed Nov 08, 2006 12:45 am
ron33030 wrote:its the ground
The ground? where is that located?
I'ma take it back to the garage tomorrow and make them check it (and possibly get them to pay for the ticket i got).
LatinDragonXJC
Postby LatinDragonXJC » Wed Nov 15, 2006 2:48 pm
bump
Does anyone know where I could find the ground wire for the DRLs? I figured out through some searching on other sites, and they all point to it not being grounded properly.
Sorry didn't want to start a new thread and waste space.
LatinDragonXJC
Postby SolaraBlue » Wed Nov 15, 2006 3:43 pm
im having this same issue.... changed the fuses. nothing....
http://www.solaraguy.org/viewtopic.php? ... sc&start=0
Postby Turbosolara » Wed Nov 15, 2006 10:10 pm
always check fuse first. There is a parking light fuse, check if it is blown
Postby LatinDragonXJC » Wed Nov 15, 2006 10:27 pm
SolaraBlue wrote:im having this same issue.... changed the fuses. nothing....
I read your thread, did you ever get it working? And where your tailights out too, in the same manner?
LatinDragonXJC
Postby LatinDragonXJC » Wed Nov 15, 2006 10:57 pm
Turbosolara wrote:always check fuse first. There is a parking light fuse, check if it is blown
I did that of course, It was blown. and like SolaraBlue did, I replaced it, no result. I'ma check it again to see if that one blew too.
LatinDragonXJC
Postby SolaraBlue » Thu Nov 16, 2006 8:03 am
yep. EXACT same problems as you. tailights and corners... i havnt gotten it to work yet. ill let you know when i do....
Postby Nyyankees3511 » Thu Nov 16, 2006 9:54 am
Is your light out function on in the cluster?
Nyyankees3511
Postby SolaraBlue » Thu Nov 16, 2006 9:56 am
checked wires nothing touching..i know its soooo simple i just cant figure it out...
Postby LatinDragonXJC » Thu Nov 16, 2006 1:31 pm
SolaraBlue wrote:checked wires nothing touching..i know its soooo simple i just cant figure it out...
That's exactly what I'm thinking, it should be such a simple fix but can't figure it out. And I really dont wanna take it to the shop, cuz they're gonna take my car for the entire day to fix it, which I doubt they need. I'ma keep researching it, I'll let you know if I have any luck also.
LatinDragonXJC
Postby SolaraBlue » Thu Nov 16, 2006 4:02 pm
i feel the same way too. i want it fixed but dont want to waste money on a mechanic when i know its something so simple. if i dont have it fixed by the end of the weekend im taking it in to get fixed. not being able to drive at night is killing my schedule. let me know if you find a solution.
i have to keep reminding myself i drive a toyota not an audi....
