SolaraGuy.com • View topic - timing belt
timing belt
timing belt
Postby Solara916 » Sun Nov 12, 2006 11:50 am
I went into Goodyear to get a quote on a 90k mile maintenance. They say i should get my timing belt and water pump replaced. How necessary is that? I've already had my water pump changed once, and I think that was unnecessary then. All in all they want to charge me about 1k for all the services and labor.
Any feedback would be appreciated.
Solara916
Postby onefiend » Sun Nov 12, 2006 11:57 am
read this thread
http://www.solaraguy.org/viewtopic.php?t=27200
1K is way too much.
2007 Camry SE V6
onefiend
Postby Midias » Sun Nov 12, 2006 1:09 pm
did mine at 90k belt and pump for about 500 at dealer
Postby bassthrive » Sun Nov 12, 2006 2:27 pm
Midias wrote:did mine at 90k belt and pump for about 500 at dealer
did that $500 include drive belts as well? (alternator and PS v-belts)
got a quote from my dealer over the phone...
timing belt
drive belts
cam/crank seal (didnt understand the explanation for this)
water pump
rental car
$800 total
good deal or sh!t deal?
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Mole » Sun Nov 12, 2006 5:14 pm
if you want to go to the dealer, ask if they have a coupon running around. which most likely they always do.
and to the OP- to get to the timming belt the water pump is right there with it, so its like hitting 2 birds with 1 stone.
Postby Midias » Sun Nov 12, 2006 8:05 pm
YES all belts brought it in on a thursday and out on friday night.
Postby mettler » Wed Nov 15, 2006 6:49 am
should the timing belt be done every 90k miles? For some reason I thought it was every 60k.
thanks
http://www.facebook.com/pages/Ice-Dragon-Cooling/139536759426738
mettler
Postby Too Bzy » Wed Nov 15, 2006 10:28 am
Has anyone gotten a dealer deal with a S/C set up? What are people paying for a belt replacement with S/C?
Charles "Cee-Jay" Hughes
99 TRD Solara S/C LB GP Ed. 23 of 35
86 Supra w/ 6M-GTE
Too Bzy
Postby Jon11582 » Wed Nov 15, 2006 11:58 am
mettler wrote:should the timing belt be done every 90k miles? For some reason I thought it was every 60k.
thanks
Its 90k for belts for all Solara engines but the 2AZ. 2AZ never needs their timing chains changed.
60K is plugs, 90k is belts.
I dont believe the water pump is actually part of the Toyota standard maintenance schedule and should last the lifetime of your car with other proper maintenance. However, many mechanics change them together as the labor is almost exactly the same in getting to the timing belt as getting to the water pump. If youve already had your pump changed, you dont need to change it again. Be aware that the labor for the pump and belts should be about the same, 90% of the work is the same for both - If they are charging you full labor for both, you're getting double charged.
2000 Black Solara SE
Jon11582
Postby Midias » Wed Nov 15, 2006 12:44 pm
When I got my belt done the guy quoted me the same labor charge pump or not :).
