SolaraGuy.com • View topic - Auto-on Headlights
Auto-on Headlights
Auto-on Headlights
Postby Guest » Mon Mar 17, 2003 8:16 am
I'm currently driving a 00 Celica GT-S, and they have the auto-on headlights too. I don't particularly like the option, and there is a wire that was able to be cut to disable it on the Celica.
I'm about to trade for a 99-00 Solara SLE V6, and was wondering if there is a similar fix to disable the auto-on lights on the Solara? Thanks!
Guest
Postby Jackass-Jeff » Mon Mar 17, 2003 9:16 am
If you mean the daytime running lights, yes. I own a 02 and we have the switch, but if you use the "SEARCH" function, you will find the post on how to disable the daytime lights (or daytime sensor) on the 99-01.
1GR-FE ftw!
Jackass-Jeff
Postby Jackass-Jeff » Mon Mar 17, 2003 9:19 am
Here, I found a good one for you...
http://www.zer0.info/solaraguy/viewtopi ... hlight=drl
1GR-FE ftw!
Jackass-Jeff
Postby Yanks0114 » Mon Mar 17, 2003 1:21 pm
Na, i don't think he was talking about DRLs. On my 01 solara the lights automatically come on when it gets dark. The way you disable them is to disconnect the sensor. Ours is located in the top right hand corner of the dashboard. You pop the sensor up and there is a little connector with 3 wires which just pops up.
If anyone has the haynes manual, can you tell me which of those three wires is the power wire. I want to put a switch on my sensor so i can manually shut the lights off.
The light switch override was added for 02.
Postby impactX » Mon Mar 17, 2003 2:40 pm
Yanks0114 wrote:Na, i don't think he was talking about DRLs. On my 01 solara the lights automatically come on when it gets dark. The way you disable them is to disconnect the sensor. Ours is located in the top right hand corner of the dashboard. You pop the sensor up and there is a little connector with 3 wires which just pops up.
Use a voltmeter.
impactX
Postby Guest » Mon Mar 17, 2003 3:22 pm
That's what I was talking about, thanks. I saw the DRL disable when I searched, just wondering about the auto-on. I hope to pick up my 99 SLE V6 tomorrow! :D
Guest
Postby Yanks0114 » Mon Mar 17, 2003 4:57 pm
Anonymous wrote:That's what I was talking about, thanks. I saw the DRL disable when I searched, just wondering about the auto-on. I hope to pick up my 99 SLE V6 tomorrow! :D
congrats on getting a new car man
Postby Yanks0114 » Mon Mar 17, 2003 4:59 pm
impactX wrote:Use a voltmeter.
I was considering using a digital multi meter but its going to be very hard to get a reading from the wires. You are working underneath the dash, so i need to lay upside down. Its high up in the dash and there is on a few inches to work with. I can't get access to the plug to get a reading so i'd need to splice into the wire. Plus, i've found it very difficult to get them to turn on when its light out, i'm sure i could just cover the sensor but its still a pain
Postby impactX » Mon Mar 17, 2003 8:39 pm
Actually, I was thinking about pulling the plug upward instead of working underneath the dash :D
impactX
Postby Yanks0114 » Tue Mar 18, 2003 6:48 am
impactX wrote:Actually, I was thinking about pulling the plug upward instead of working underneath the dash :D
Tried to, there wasn't enough cord at all. I had my whole glovebox out and i was trying to work on it and there were only a few inches to work with after rerouting the wires. But the way it normally runs, there was not enough space
