SolaraGuy.com • View topic - Tools for replacing struts & mounts
Postby Jeffrey Olson » Tue Dec 12, 2006 7:41 am
What combination of tools have listers used to take out and install struts? What size is the socket needed for the two big bolts - 22mm???
Can you use a half inch drive socket with extension and then a half inch ratchet or do you need a breaker bar? Is 1/2" big enough to crack those nuts?
Thanks
Jeff
Jeffrey Olson
Postby CASTRO » Tue Dec 12, 2006 11:12 am
ive always trusted in my breaker bar, never let me down. if the breaker bar fails, I add a copper pipe to extend it. lol
CASTRO
Postby unbalancedwood » Tue Dec 12, 2006 11:37 am
19mm for the main strut hat screw
15mm for somthing else, lol
I used a 4 way thingy for the two huge bolts that hold the strut and rotor assembly together (7/8")
Then some various smaller wrenches
and a monkey wrench to hold one of the control arms in place while you wrench on it.
Some spring compressors rented from Advanced Auto ($50 down, you get it back)
Some greese, locktite, and maybe some penetrating oil
I never used a breaker bar just pure muscle :)
Thats all i could think of...
unbalancedwood
Postby DaTwUnKrAziEpInOy » Tue Dec 12, 2006 12:00 pm
Air compressor + Impact Gun :D Makes life so easy. LOL
DaTwUnKrAziEpInOy
Postby unbalancedwood » Tue Dec 12, 2006 4:29 pm
^ those two things would have made my life really easy in compressing the springs, everything else isnt 'that bad'
I would say now that ive been experienced, spent an hour trying to figure out how to get the assembly out. I accidently took out the top shock screw, thus the spring wasent compressed.
With the basics I could do the fronts (dissassembly > change out > assembly) in 45mins each. Not sure about the rears, but heard there a little harder.
unbalancedwood
